Issue in running VREP in a cluster
martin
Post by martin »
Hi Coppelia,
I am trying to run VREP in headless mode in a computational cluster and I connot do that, which I deduce are due to the version of Linux installed in the cluster. The cluster version is:
NAME = "Red Hat Enterprise Linux Server"
VERSION = "7.5 (Maipo)"
ID = "rhel"
ID_LIKE = "fedora"
VARIANT = "Server"
VARIANT_ID = "server"
VERSION_ID = "7.5"
I have tried to run the last two versions of VREP that are on the web page for linux (both for ubuntu) obtaining the following results:
V-REP_PLAYER_V3_6_2_Ubuntu18_04:
Loading the V-REP library ...
Error: could not find or correctly load the V-REP library
V-REP_PLAYER_V3_6_2_Ubuntu16_04:
qt.qpa.xcb: could not connect to display
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb.
Donate
Launching V-REP ...
V-REP PLAYER V3.6.2. (rev. 0)
/mnt/netapp2/Home_FT2/home/ulc/ii/mnv/V-REP_PLAYER_V3_6_2_Ubuntu16_04/./vrep.sh: line 33: 7493 Aborted (`core 'generated)" $ dirname / $ appname "" $ {PARAMETERS [@] } "
srun: error: c0910: task 0: Exited with exit code 134 "
Have you got any idea how can I run VREP in that cluster?
Regards!
Re: Issue in running VREP in a cluster
Either use Ubuntu or build V-REP from source.
pranali
Post by pranali »
Even I'm trying to run on the cluster (red hat Linux). But it's not running on it. Any solutions?
pranali wrote: 05 Aug 2023, 10:36 Even I'm trying to run on the cluster (red hat Linux). But it's not running on it. Any solutions?
As stated by fferri, try to rebuild CoppeliaSim for Red Hat Linux, or then run the Ubuntu version on an Ubuntu cluster. We officially only support Ubuntu in the Linux world, but other distributions should work fine too if you rebuild CoppeliaSim.
