I wanted to create a counter (with deletion box) just like the ones in blobDetectionWithPickAndPlace.ttt using the Qt-based custom UI's (Since the scene is based on OpenGl-based custom UI which seems to have been removed a while back) . Is there any example or scene that one could use as a tutorial or a reference? If not, any hints as to which functions to use?
Cheers,
mohtashem
Creating a counter using UI elements
Re: Creating a counter using UI elements
You can create a label and change its text with
simUI.setLabelText
, e.g.:Code: Select all
ui=simUI.create([[<ui>
<label id="100" text="Count:" />
<label id="101" text="0" style="font-size: 30px" />
</ui>]])
count=0
function sysCall_actuation()
count=count+1
simUI.setLabelText(ui,101,''..count)
Exactly what's needed. Thank you so much.
Cheers,
mohtashem
Cheers,
mohtashem
