weird movement
Mohamed Magdy
weird movement
Post by Mohamed Magdy »
hey
I can not solve the weird movement of the robot during following a path
here is a video explaining :https://drive.google.com/open?id=1plN9G ... fXf-UQCHNl
thanks you team coppelia for supporting us .
Re: weird movement
Please post the scene, from the video it is very difficult to guess what is wrong.
Mohamed Magdy
Re: weird movement
h
Re: weird movement
I had a quick look at your robot. The kinematics are too complicated and ill-designed. You have 4 IK groups. Why? Each IK group will be executed sequentially. So there is no simultaneous computation of all constraints as you would have if you had all IK elements inside of a same IK group.
It is really very important to build a tree-like kinematic structure. Each branch that closes needs to close on a non-moving item (i.e. the base of the robot).
Also, using a damped resolution method might help you at first, but it will hide some over-constrain problems you might have.
Mohamed Magdy
Re: weird movement
coppelia wrote: 03 Oct 2019, 12:37
hey
I think it's impossible to this with hybrid robot because I have the platform which connected in the parallel and serial structure and for that I used dummies as you can see in the scene tree ..please tell me how to do what you are saying !
also
Mohamed Magdy
Re: weird movement
I tried this
base --> revJoint --> revJoint --> prismJoint2 --> revJoint --> platform --> revJoint --> prismJoint 1--> revJoint --> tipA
platform --> revJoint --> prismJoint3 --> revJoint --> tipB
platform --> revJoint --> revJoint --> tipC (at the tip of tool)
--> targetA
--> targetB
but arm 1,3 are also connected with moving item (upper base )which is connected with the base with rev joint
https://drive.google.com/open?id=1TNNSP ... b_Hs-C7Lxd
Re: weird movement
That will not work. You really have to create a tree-like structure. Not many trees, but a single tree. Typically something like:
base -> joint1 -> joint2 -> link1 ->joint3 -> joint4 -> platform -> joint5 -> ...
        -> joint6 -> ...
        -> joint7 -> ...
     -> target1
     -> target2
     -> target3
Mohamed Magdy
Re: weird movement
I made a single tree with three branches like in the pic , am I misunderstanding ?
Re: weird movement
You have a very comple robot. Describing how to build the kinematic model is therefor complicated. But as stated, the very first thing is to have a single tree. Then you can consider individual tree branches for closing those branches. Have a look at how the models models/robots/non-mobile/ABB IRB 360.ttm and models/robots/non-mobile/adept Quattro 650HS.ttm were made. Also, have a very close look at the various examples located in scenes/ik_fk_simple_examples
Mohamed Magdy
Re: weird movement
hey
may I ask another question .
when i use graph to get joint position of Rev_joint 5 ,it shows changing in joint position despite I can see it stationary !!
