Where did the path planning tab go in V-REP 3.6.2? It used to be among the calculation modules tabs in earlier versions.
Thank you.
Where is Path Planning in V-REP 3.6.2?
Re: Where is Path Planning in V-REP 3.6.2?
you can access it in older versions or use http://www.coppeliarobotics.com/helpFil ... odules.htm
more flexible
more flexible
That functionality was removed. We highly recommend to use the path planning functionality provided by the OMPL plugin.
