Hey, I am trying to open vrep.sh by typing "./vrep.sh" in command line, finally, it first shows some successful loading of plugins, and also prompt of the v-rep window jumps out. But suddenly it closes and says "./vrep.sh : line 33 6396 Illegal instruction (core dumped) "$dirname/$appname" "${PARAMETERS[@]}"
However, V-rep 3.6.1 works well, can anyone show me how to let 3.6.2 function properly?
V-rep 3.6.2 doesn't work in Ubuntu 18.04 LTS
Re: V-rep 3.6.2 doesn't work in Ubuntu 18.04 LTS
can you tell me what the console says just before crashing? Is one plugin the culprit maybe?
You can find out by removing the plugin from the V-REP folder and trying again.
I got the same issue when moving to VREP 3.6.2 on Ubuntu 18.04 LTS.
"vrep.sh" crashes at the last line ("$dirname/$appname" "${PARAMETERS[@]}") corresponding to thee execution of the vrep executable.
The log of vrep execution is the following :
Loading the V-REP library...
Done!
Launching V-REP...
V-REP PRO EDU V3.6.2. (rev. 0)
Add-on script 'vrepAddOnScript-b0RemoteApiServer.lua' was loaded.
Add-on script 'vrepAddOnScript_PyRep.lua' was loaded.
If V-REP crashes now, try to install libgl1-mesa-dev on your system:
OpenGL: NVIDIA Corporation, Renderer: Quadro FX 5800/PCIe/SSE2, Version: 3.3.0 NVIDIA 340.107
...did not crash.
Simulator launched.
Plugin 'MeshCalc': loading...
Plugin 'Assimp': loading...
Plugin 'Assimp': warning: replaced variable 'simAssimp'
Plugin 'Assimp': load succeeded.
Plugin 'BlueZero': loading...
Plugin 'Bwf': loading...
Plugin 'Bwf': load succeeded.
Plugin 'CodeEditor': loading...
Plugin 'CodeEditor': load succeeded.
Plugin 'Collada': loading...
Plugin 'CustomUI': loading...
Plugin 'CustomUI': warning: replaced variable 'simUI'
Plugin 'CustomUI': warning: replaced function 'simUI.insertTableRow@CustomUI'
Plugin 'CustomUI': warning: replaced function 'simUI.removeTableRow@CustomUI'
Plugin 'CustomUI': warning: replaced function 'simUI.insertTableColumn@CustomUI'
Plugin 'CustomUI': warning: replaced function 'simUI.removeTableColumn@CustomUI'
Plugin 'CustomUI': warning: replaced function 'simUI.setScene3DNodeParam@CustomUI'
vrep executable seems to crash when loading "DynamicsVortex" plugin
If you do not use the Vortex plugin , a possible workaround is to prevent the loading of the plugin (e.g. by renaming it)
mv libv_repExtDynamicsVortex.so to_libv_repExtDynamicsVortex.so
This does not solve the problem if you use Vortex but for other solvers (Bullet, Ode and Newton) it seems to work fine.
KInd regards
Done!
Launching V-REP...
...did not crash.
Simulator launched.
KInd regards
Thanks for the info.
