How to load a mirror object into the scene?
bchen
Post by bchen » 29 Oct 2019, 17:41
Hi, may I ask how can we load a mirror object into the scene? I saw the documentation here: http://www.coppeliarobotics.com/helpFil ... irrors.htm. However, I am not able to find "Mirror" option under Add. Could you please kindly instructed?
Thank you!!
Re: How to load a mirror object into the scene?
Post by coppelia » 01 Nov 2019, 11:47
mirrors are unfortunately not supported anymore. At least until we have replaced the rendering engine. Sorry about that.
bchen
Post by bchen » 03 Nov 2019, 21:41
Thank you for your reply!
Do you by any chance know if there is any walk around to get the mirror in V-REP? It is a very important component for our research project.
Cheers!
Post by coppelia » 05 Nov 2019, 11:43
Hello again,
ok, we'll try to add an API function for that. Next release should be out in 2-3 weeks. With following you will be able to add a mirror with dimensions x,y:
handle=sim.auxFunc('createMirror',{x,y})
bchen
Post by bchen » 07 Nov 2019, 22:25
Thank you so much! This will be a very valuable tool for our research!!
Cheers!
