CodeEditor loading problem
zdenoB
Post by zdenoB »
I have a problem with CodeEditor loading problem under Ubuntu 18.04.
When I run vrep with sudo, then everything works fine. CodeEditor load Succeeded.
But when I run in without sudo, then i get this information:
CodeEditor': loading...
Error with plugin 'CodeEditor': load failed (could not load). The plugin probably couldn't load dependency libraries. For additional infos, modify the script 'libLoadErrorCheck.sh', run it and inspect the output.
In libLoadErrorCheck is defined:
ldd "$dirname/libv_rep.so" #replace libv_rep.so with the library that is having difficulties to load
but I don't know the name of Library behind CodeEditor.
I would like to run vrep without sudo. Is there a chance to solve it?
Thanks in advance.
Zdeno
Re: CodeEditor loading problem
zdenoB wrote: 31 Oct 2019, 08:01 ldd "$dirname/libv_rep.so" #replace libv_rep.so with the library that is having difficulties to load
libv_repExtCodeEditor.so
zdenoB
Post by zdenoB »
Thanks a lot, but what now?
I have output from libLoadErrorCheck.sh without sudo:
linux-vdso.so.1 (0x00007ffe6e7e3000)
libQt5Xml.so.5 => /home/zdeno/Downloads/V-REP_PRO_EDU_V3_6_2_Ubuntu18_04/libQt5Xml.so.5 (0x00007f31545fd000)
libqscintilla2_qt5.so.13 => /usr/lib/libqscintilla2_qt5.so.13 (0x00007f3153f49000)
libQt5Widgets.so.5 => /home/zdeno/Downloads/V-REP_PRO_EDU_V3_6_2_Ubuntu18_04/libQt5Widgets.so.5 (0x00007f31536fd000)
libQt5Gui.so.5 => /home/zdeno/Downloads/V-REP_PRO_EDU_V3_6_2_Ubuntu18_04/libQt5Gui.so.5 (0x00007f3152ed7000)
libQt5Core.so.5 => /home/zdeno/Downloads/V-REP_PRO_EDU_V3_6_2_Ubuntu18_04/libQt5Core.so.5 (0x00007f3152744000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f31523bb000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f31521a3000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f3151db2000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f3151b93000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f31517f5000)
libQt5PrintSupport.so.5 => /home/zdeno/Downloads/V-REP_PRO_EDU_V3_6_2_Ubuntu18_04/libQt5PrintSupport.so.5 (0x00007f3151583000)
libGL.so.1 => /usr/lib/x86_64-linux-gnu/libGL.so.1 (0x00007f31512f7000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f31510da000)
libicui18n.so.56 => /home/zdeno/Downloads/V-REP_PRO_EDU_V3_6_2_Ubuntu18_04/libicui18n.so.56 (0x00007f3150c41000)
libicuuc.so.56 => /home/zdeno/Downloads/V-REP_PRO_EDU_V3_6_2_Ubuntu18_04/libicuuc.so.56 (0x00007f3150889000)
libicudata.so.56 => /home/zdeno/Downloads/V-REP_PRO_EDU_V3_6_2_Ubuntu18_04/libicudata.so.56 (0x00007f314eea6000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f314eca2000)
libgthread-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0 (0x00007f314eaa0000)
libglib-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007f314e789000)
/lib64/ld-linux-x86-64.so.2 (0x00007f3154ad6000)
libGLX.so.0 => /usr/lib/x86_64-linux-gnu/libGLX.so.0 (0x00007f314e558000)
libGLdispatch.so.0 => /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007f314e2a2000)
libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007f314e030000)
libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007f314dcf8000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007f314dad0000)
libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007f314d8cc000)
libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007f314d6c6000)
libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007f314d4b1000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f314d2a9000)
and with sudo:
linux-vdso.so.1 (0x00007fff945e9000)
libQt5Xml.so.5 (0x00007fc679665000)
libqscintilla2_qt5.so.13 (0x00007fc6790ed000)
libQt5Widgets.so.5 (0x00007fc6788a1000)
libQt5Gui.so.5 (0x00007fc67807b000)
libQt5Core.so.5 (0x00007fc6778e8000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fc67755f000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fc677347000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fc676f56000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fc676d37000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fc676999000)
libQt5PrintSupport.so.5 (0x00007fc676727000)
libGL.so.1 => /usr/lib/x86_64-linux-gnu/libGL.so.1 (0x00007fc67649b000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fc67627e000)
libicui18n.so.56 (0x00007fc675de5000)
libicuuc.so.56 (0x00007fc675a2d000)
libicudata.so.56 (0x00007fc67404a000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fc673e46000)
libgthread-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0 (0x00007fc673c44000)
libglib-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007fc67392d000)
/lib64/ld-linux-x86-64.so.2 (0x00007fc679b3e000)
libGLX.so.0 => /usr/lib/x86_64-linux-gnu/libGLX.so.0 (0x00007fc6736fc000)
libGLdispatch.so.0 => /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007fc673446000)
libpcre.so.3 => /lib/x86_64-linux-gnu/libpcre.so.3 (0x00007fc6731d4000)
libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007fc672e9c000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007fc672c74000)
libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007fc672a70000)
libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007fc67286a000)
libbsd.so.0 => /lib/x86_64-linux-gnu/libbsd.so.0 (0x00007fc672655000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fc67244d000)
How can I find a "broken" permission?
Maybe you can try with the beta version of CoppeliaSim, which is to replace V-REP.
zdenoB
Post by zdenoB »
coppelia wrote: 13 Nov 2019, 16:49 Maybe you can try with the beta version of CoppeliaSim, which is to replace V-REP.
Thank you. I tried it, but I have the same result.
