the velocity is linear or angular velocity
Sophia
Post by Sophia » 06 Nov 2019, 10:08
In the function simSetJointTargetVelocity ,i set a velocity. And the joint is connect with a wheel. so the velocity i set is the wheel's linear velocity or angular velocity?
Re: the velocity is linear or angular velocity
Post by coppelia » 06 Nov 2019, 15:21
sim.setJointTargetVelocity sets the desired velocity of a joint. If the joint is prismatic, then it is the linear velocity. If the joint is revolute, then it is the angular velocity.
Sophia
Post by Sophia » 07 Nov 2019, 03:33
got it. thank you!
