How to interact with robot through a laserpointer ?
jianye
Post by jianye » 12 Nov 2019, 15:44
hello guys,
ich have built a Safety Light Curtain modell with laserpointer.
And the work situation is described as follows:
1 if the worker walks through the laserpointer, then the robot should stop.
2 And at the same time when the worker in the area of Safety Light Curtain and the light is not interrupted by the worker, the robot keep the stopped Status,
3 and when the worker finished the job and go through the Safety Light Curtain again and the robot moved again.
but i use the function sim.handleProximitySensor() to get the data of distance. The code is listed as follows:
function sysCall_actuation()
    --local scannerData=sim.getStringSignal("measuredDataAtThisTime")
    --local activateStatus = false
    for i=1,zCnt,1 do
        res={}
        distance={}
        pt={}
        res,distance,pt=sim.handleProximitySensor(sensor_pointer[i])
    if distance  <0.9 then
        counter=counter+1
    if distance < 0.9 then
        sim.setStringSignal("SafetyStop","1")
        elseif counter%2 ~= 0 then
            sim.setStringSignal("SafetyStop","0")
but this code didn't work.
any advice ?
thanks
Jian
Re: How to interact with robot through a laserpointer ?
Post by coppelia » 13 Nov 2019, 17:07
Hello Jian,
the simplest would be to modify the existing laser pointer model (I suppose you used the one available in the model library?). In the child script attached to it, in the sensing section, simply focus on the first line:
    res,dist,pt=sim.handleProximitySensor(sensor)
If res>0, then dist is the distance measured to the next obstacle. Otherwise nothing is detected.
If you are using ray-type proximity sensors, it is the same.
jianye
Post by jianye » 13 Nov 2019, 19:59
hello,
thank you for the reply.(^-^)
I have used the code you mentioned. And now i can only use the change of distance to identify that the person go through the Safety Light Curtain. Only in this moment i can let the robot-arm to stop. But when the person entirely get in this area and the light of pointer is not interrupted. Then the robot-arm move again.
but i want to know how can i control the robot that , when the person stands in the safe area and robot-arm don't also move?
And the next step what i want is that the robot-arm will move again when the person entirely leave the safe area ?
Thanks again for your reply.
Jian
Post by coppelia » 14 Nov 2019, 09:50
You will have to set-up a switch. But that will not be reliable, since counting detections might wrongly assume the person has gone in or come out (maybe turned around in mid-way).
Better would be to have a large sensor for the whole aera.
