How to set the table that the people won't go through it?
jianye
Post by jianye » 28 Nov 2019, 15:02
hello guys,
I have pulled a table model(customizableTable) and people model(Bill on Path.ttm) in the scene and the person goes through the table.
what can I do without sensor that the people won't go through the table? (How can I set the table as a fixed obstacle for people that people can not go through it ?)
thanks in advance.
Jian Ye
Re: How to set the table that the people won't go through it?
Post by coppelia » 02 Dec 2019, 10:12
Hello Jian,
the model Bill on Path.ttm is a model of a person that will follow a fixed path (that's why it is called Bill on path). You can either modify the path object, so that Bill doesn't walk through the table, or then you should use a different model of Bill, that has sensors attached. There is also Walking Bill, that will walk on a straight line and change direction if an obstacle is detected.
Or, of course, you can always use the existing models and modify them for a very specific behaviour.
