problem when use B0basedReomoteApi to read the data from simulation
jianye
Post by jianye » 22 Dec 2019, 21:30
hello,
i am working on Vrep and want to use Python through B0basedRemoteApi.
In the Simulation i have set the two collection an want to read the distance betweem this two collections.
when I write the code in the lua script with no b0basedRemoteApi:
mensch_handle=sim.getCollectionHandle('BillsCollection#')
robot_handle=sim.getCollectionHandle('UR10Collection#')
res,data=sim.checkDistance(mensch_handle,robot_handle,1000)
print(data)
all things work gut, but when I write the following code in my python script with b0BasedRemoteApi:
mensch_handle=client.simxGetCollectionHandle('BillsCollection#',client.simxServiceCall())
robot_handle=client.simxGetCollectionHandle('UR10Collection#',client.simxServiceCall())
client.simxSynchronous(True)
client.simxAddStatusbarMessage('Hello world!',client.simxDefaultPublisher())
distdata=client.simxCheckDistance(mensch_handle[1],robot_handle[1],0,client.simxServiceCall())
print(distdata[1])
it didn't work and I got this error:
b".//lua/b0RemoteApiServer.lua:876: attempt to call local 'f' (a nil value)"
any advice?
thanks in advance
jian
Re: problem when use B0basedReomoteApi to read the data from simulation
Post by coppelia » 31 Dec 2019, 08:07
Hello Jian,
sorry for the late reply. Actually that is a bug. You can fix this by changing line 598 of file lua/b0RemoteApiServer.lua from:
return sim.getCollectionHandle(objName..'#')
to
return sim.getCollectionHandle(objName)
