How to quick reset the simulation like clicking the stop and start buttons?
JackL
Post by JackL » 23 Dec 2019, 09:32
My simulation model in v-rep is a quadrotor and I want to control it in Matlab through the remote API. Each time I restart the simulation I need to reclick the stop and start buttons in v-rep to reset the simulation. Is there any way to avoid clicking buttons to achieve a quick reset though the remote API in Matlab? I know the function 'simResetDynamicObject'. but the function will not reset the object to starting position and attitude. Is there any way to reset simulation that has the same effect as clicking the stop and start buttons. Thanks.
Re: How to quick reset the simulation like clicking the stop and start buttons?
Post by fferri » 23 Dec 2019, 09:47
You can store the position and orientation of all the relevant objects in a variable, and reset it (and also call simResetDynamicObject).
e.g.:
    movingObjects={'Cuboid'}
    pos={}
    orient={}
    for k, v in pairs(movingObjects) do
        h=sim.getObjectHandle(v)
        movingObjects[k]=h
        pos[h]=sim.getObjectPosition(h,-1)
        orient[h]=sim.getObjectOrientation(h,-1)
function reset()
        sim.setObjectPosition(v,-1,pos[v])
        sim.setObjectOrientation(v,-1,orient[v])
        sim.resetDynamicObject(v)
Post by coppelia » 31 Dec 2019, 08:59
what about simply stopping and restarting the simulation from your remote API client side, using simxStopSimulation, followed by simxStartSimulation? After calling simxStopSimulation, you should however wait a few pings, since stopping a simulation will not immediately stop it (the simulation first need to inform threaded scripts to stop, wait for that, then run a last simulation step, then stop)
e.g.
sim.simxStopSimulation(clientID,sim.simx_opmode_blocking);
is_running = true;
while is_running
    error_code, ping_time = sim.simxGetPingTime(clientID);
    error_code, server_state = sim.simxGetInMessageInfo(clientID, sim.simx_headeroffset_server_state);
    is_running = bitand(server_state,1);
sim.simxStartSimulation(clientID,sim.simx_opmode_blocking);
