How to use the b0-based remote API on multiple PCs
masatomori
Post by masatomori » 14 Jan 2020, 02:49
Dear Coppelia,
I would like to access CoppeliaSim using the b0-based remote API with two PCs as client and server respectively.
I use Matlab as my client.
However, I was not able to succeed in these communications.
Do I need to set an IP address like 192.168.0.10 somewhere on the client side?
I thought it might be to set the IP address, like the legacy remote API,
but I didn't see any documentation about this.
If I run client (Matlab) and server (CoppeliaSim) on the same PC, I succeeded.
How can I solve this problem?
I will appreciate your help with this situation.
masato
Re: How to use the b0-based remote API on multiple PCs
Post by coppelia » 14 Jan 2020, 12:26
Hello Masato,
a B0 node will look at the environment variable B0_RESOLVER, e.g.:
export B0_RESOLVER=tcp://localhost:22000
launch B0 node
on the other hand, the resolver itself will look at B0_RESOLVER_PORT, e.g.:
export B0_RESOLVER_PORT=22000
launch B0 resolver
