B0 resolver could not be launched.
fool
Post by fool » 14 Jan 2020, 02:58
Hi,I have some questions about B0-basedRemoteApiDemo.ttt,
When I run it, it always warns that:
B0 resolver was not detected. Launching it from here...
What should I do to complete the remote connection?
In the working folder I have prepared all the required libraries,When I run, it always stops on initialization
Re: B0 resolver could not be launched.
Post by coppelia » 14 Jan 2020, 06:24
can you try following?
In file CoppeliaSimInstallFolder/lua/b0RemoteApiServer.lua, replace
                sim.launchExecutable('b0_resolver','',1)
with
                local st=sim.getSystemTimeInMs(-1)
                while sim.getSystemTimeInMs(st)<5000 do end
Let me know if that makes a difference.
Also, when you manually try to run B0Resolver, what is the output exactly?
fool
Post by fool » 14 Jan 2020, 08:21
Thank you very much for your answer!
I'm trying to communicate with vrep using matlab.
I modified the code and ranB0-basedRemoteApiDemo.ttt,then start script in the menu bar [Add-ons --> b0RemoteApiServer],The output is:
[15:08:06] B0 Remote API: creating BlueZero node 'b0RemoteApi_V-REP' and associated publisher, subscriber and service server (on channel 'b0RemoteApi')
B0 Remote API: B0 resolver was not detected. Launching it from here...
[15:08:25] B0 Remote API: B0 resolver could not be launched.
[15:09:47] B0 Remote API (add-on): creating BlueZero node 'b0RemoteApi_CoppeliaSim-addOn' and associated publisher, subscriber and service server (on channel 'b0RemoteApiAddOn')
[15:10:06] B0 Remote API (add-on): B0 resolver could not be launched.
When I run B0Resolver manually,The B0Resolver window only appears for a while and then disappears,Then nothing happened
Post by coppelia » 14 Jan 2020, 13:29
can you tell me what platform you are running on?
Also, can you try to start b0_resolver from the DOS console or the Ubuntu terminal and tell me the output?
fool
Post by fool » 16 Jan 2020, 09:00
hello,coppelia!
Thanks for your reply!
My platform is WINDOWS10, I cannot start b0_resolver from DOS。If I run it with administrator privileges alone, the window of
b0_resolver is only displayed for a while without any output。
Also when I open B0-basedRemoteApiDemo.ttt, this will appear in the middle of the scene:
‘’CUSTOMIZATION SCRIPT b0RemoteApiServer: abort execution‘’
Post by coppelia » 16 Jan 2020, 13:56
Thank you. I meant to say: start b0_resolver in the DOS console (i.e. by typing b0_resolver.exe<return>, not by double-clicking it). What is the exact output of the DOS console? Also, make sure to run b0_resolver from the CoppeliaSim installation folder, since b0_resolver depends on other dlls.
fool
Post by fool » 18 Jan 2020, 13:43
hi,coppelia
I started b0_resolver with DOS, and then there was no response, not even the b0_resolver interface, and there was output
like this:
"C:\Program Files\CoppeliaRobotics\CoppeliaSimEdu>b0_resolver.exe
C:\Program Files\CoppeliaRobotics\CoppeliaSimEdu>"
What should i do to solve this?
Post by coppelia » 20 Jan 2020, 06:55
What does it say if you type:
b0_resolver.exe -Ldebug
fool
Post by fool » 21 Jan 2020, 09:25
Thank you very much for your reply!
If I type the above code, the output of DOS is that:
“C:\Program Files\CoppeliaRobotics\CoppeliaSimEdu>b0_resolver.exe -Ldebug
2020-01-21 16:23:49 [resolver] debug: Initialization...
2020-01-21 16:23:49 [resolver] debug: ServiceClient(resolv): Skipping resolution because remote address (tcp://御坂美琴:
22000) was given
C:\Program Files\CoppeliaRobotics\CoppeliaSimEdu>”
Thanks again for your help, but I am going to use the old version of the remote API. Thanks!
Post by fferri » 21 Jan 2020, 10:38
could it be that your machine it is not reachable by its host name (御坂美琴) via the IP protocol?
Try executing the following
set B0_HOST_ID=127.0.0.1
before running b0_resolver (replace 127.0.0.1 with your local IP address if you are using multiple machines).
