Kinect Color Camera error
formica
Post by formica »
Hi everybody,
I'm getting a strange error using the ColorCam inside the Kinect Sensor. I can't publish the images through ros.
Using this code snippet:
topicName=simExtROS_enablePublisher('visionSensorDepthData',1,simros_strmcmd_get_vision_sensor_depth_buffer,depthCam,0,'')
	topicNameColor=simExtROS_enablePublisher('visionSensorColorCam',1,simros_strmcmd_get_vision_sensor_image,colorCam,0,'')
I got this error:
Lua call error: [string "SCRIPT kinect"]:12: Topic could not be published. (simExtROS_enablePublisher)
The Depth Image, on the contrary, is correctly sent.
Any ideas?
Re: Kinect Color Camera error
before going into this further:
This error can be generated for 2 main reasons:
  • simros_strmcmd_get_vision_sensor_image is invalid or has an invalid number (improbable)
  • colorCam is not a vision sensor. Be careful, a camera is different from a vision sensor. You can only read a vision sensor's buffers.
