Laser Sensor Reading and Full Screen option
minato
Post by minato »
I try to implement the Hokuyo sensor, but I found that the data is an array of obstacle positions (is it correct ?). Actually I want to have the data like the real Hokuyo (I mean, the ray data which represent the distance of ray trace to obstacles, for example from 0 to 180 degrees). Is there any remoteAPI which implements such case ?
I also wonder if the V-REP simulation can be run in a full-screen mode ?
Re: Laser Sensor Reading and Full Screen option
the data that comes from the Hokuyo sensor (e.g. the Hokuyo URG 04LX UG01_Fast.ttm) is a succession of coordinates, relative to the model's reference (i.e. fastHokuyo_ref):
  • pt1=x1,y1,z1
  • pt2=x2,y2,z2
  • pt3=x3,y3,z3
  • etc.
If you want distances instead of coordinates, just calculate them, e.g.: d1=sqrt(x1*x1+y1*y1+z1*z1)
You can calculate the angle between individual points with: scanAngle/(totalPointsPerScan-1)
As for now, you cannot switch to a fullscreen mode, but there might be this feature in next release (V3.0.5), to be released within 2-3 weeks.
