Wrong field of view of the video
hi, I'm trying to record a video of a simulation but te output is a video displaying only a small area of the scene (precisely top-left side of the scene). Why?
Re: Wrong field of view of the video
that shouldn't be. What OS are you using? What V-REP version? What encoder? Have you tried with a different encoder? Or with a different window size?
Thanks, i tried a different encoder and now it's ok.
Another question: how can I adjust the field of view of the video: aspect ratio, resolution and field of view (in fact what i visualize on the video is not what i visualize on the scene...everything it's a bit shifted on top)
thanks again
thanks again
That is strange. What OS are you using?
Also, could you try to remove the toolbars on the top and side, to see if the problem persists?
You should basically get the content of the main window (Model browser, scene hierarchy and scene view). Also, most encoders require the width and height to be dividable by 16. Otherwise the sides might be padded with black pixels.
Ubuntu 12.04
...yes, by removing the bottom window seems to work...if there will be further problem I'll let you know.
thanks!
thanks!
