How I connect the simulation in V-REP with a C code?
I have a problem, I can not connect a controller written in C for my robot. I don't understand how I make the connection beetween them, because I think that it's not well explain in the tutorial, anybody can help me out? Thanks..
Re: How I connect the simulation in V-REP with a C code?
make sure to read this section about the various possibilities to program/interface a V-REP simulation.
In your case, the remote API is the answer.
I made that all. But I can't make that work. I copy from the "External controller tutorial" but when the simulation star appears an scrpit error. Do you why is that? Thanks
We cannot help you when you just say: I can't make that work, or appears an script error. Seriously?
If you expect help, describe what is not working, tell us what error message appears.
Sorry about that, I just saw the strin "(script error)" in a graph, but never saw the list of errors. But when I saw your answers I looked for them and found the error. Thanks for all, and sorry again
Another question. All the code from the project have to be at the installation directory's? or could be in other folder? becuse my scene is at a folder and apparently the code's that is running, run form the principal directory. Furthermore, the code in C have to be compile? how do I make it at windows? Thanks
No, your C/C++/Java/Matlab/Python/Urbi code can run from any directory. Also, you will need a C/C++ compiler to compile your C code. Under Windows, try with VS2010 Express.
And for compile, there some MACROs that have to be defined? because I read that in a part of the usermanual, but I don't found it now.
