I am trying to follow the ROS tutorial in the official documentation.
I came to the step to create four symbolic links,
vrep_plugin/include/v_repConst.h should point onto VREP_INSTALL_DIR/programming/include/v_repConst.h
vrep_plugin/include/v_repTypes.h should point onto VREP_INSTALL_DIR/programming/include/v_repTypes.h
vrep_plugin/include/v_repLib.h should point onto VREP_INSTALL_DIR/programming/include/v_repLib.h
vrep_plugin/src/v_repLib.cpp should point onto VREP_INSTALL_DIR/programming/common/v_repLib.cpp
programming/include
Can someone help to look at it?
Thanks a lot in advance!
