Http backend at Lua
nemilya
Http backend at Lua
Post by nemilya »
Hello!
Is it possible to make simple HTTP server at Lua in V-REP?
For example to handle GET requests: http://localhost:port/action etc.
By AddOn, Plugin, script?
Thanks,
Ilya
Re: Http backend at Lua
Hello Ilya,
have a look at the demo scene SocketAndTubeCommunicationExample.ttt, which shows something similar. You will basically have to rely on the LuaSocket library for Lua (included in V-REP by default).
But you can always write a plugin that exposes specific functionality if needed.
nemilya
Post by nemilya »
Thanks!
Is it possible to make socket-server inside V-REP?
Normally that should work, we haven't tried it though..
You will have to use a threaded child script for that, and surround your luaSocket code with following instructions:
simSetThreadIsFree(true)
-- your code (do not access V-REP API functions from here!)
simSetThreadIsFree(false)
