where can i find a tutorial that explain how to extend the lua's functionalties in vrep?
Because i would to add the zeromq lua library bindings and use it inside a child script.
thank you very much for your help
Lua with zeromq
Re: Lua with zeromq
normally there is not much to do, you simply drop the various files into V-REP's directory, then, inside of your script that requires the extension library, you write something like:
Have a look how it was done with the luaSocket library (you can find one example in the demo scene socketAndTubeCommunicationExample.ttt)
extensionLib=require("nameOfTheLib")
