Crash during startup, clean install on Windows 7 machine
squiddon
Post by squiddon »
I can't seem to start VREP on my Windows 7 machines (works fine on OSX).
The console log displays:
Using default Lua library.
Then I get a vrep.exe has stopped working popup.
Is there any way of obtaining a trace so I can debug?
Re: Crash during startup, clean install on Windows 7 machine
thanks for reporting this. Can you enable a few debug switched at the top of the file system/usrset.txt and show us the output of the console (or debug log file)?
squiddon
Post by squiddon »
I've set all switches to true. I still get the same behavior and no debugLog.txt is created.
Then it could be that your folder is write protected?! If you keep sendDebugInformationToFile to false, but set all other debug variables to true, what is the console output?
squiddon
Post by squiddon »
This is what I get with sendDebugInformationToFile set to false. I'm running cmd in admin mode.
Hm, probably an OpenGl issue... Can you try to set debugOpenGl to true (also in system/usrset.txt) and check the output?
