When I start a second V-REP application, it gives the message that V-REP appeared to have crashed.
Probably because the other V-REP instance wasn't closed yet, and it does not expect two instances running at once..
Crashed message
Re: Crashed message
This message is intended. If you want to avoid that, you can start a second V-REP session from a different install directory.
Re: Crashed message
Ok. I thought it was a bit confusing, since I regularly use multiple instances of the same application at once.
Next to this: I just had a crash of V-REP, and although V-REP nicely autosaves everything, there was no autosaved scene anymore. Maybe an autosaved instance can be saved for every scene (by scene name for example). It's kind of frustrating to think that everything was autosaved and than still have some work lost..
Re: Crashed message
By the way, it doesn't crash, it hangs.
It does now again. Are there any logfiles I can send so you can figure out what is causing this? It happened this second time again when selecting the same object.
Re: Crashed message
Well, I have a reproducible situation..
It hangs every time I select one specific object and when I want to move it.
Re: Crashed message
Can you please send us the scene?
info coppeliarobotics com
Re: Crashed message
Hm, unfortunately (and thankfully) now it is gone again. Next time I will save the scene separately, and see if it stays reproducible.
