We renewed our pro licence recently so we downloaded the newest version of V-rep. I am not sure that the following "experiences" are bugs or intentionally but i need some help with these issues:
In Menu->tools->object manipulation settings dialog, the functionalities will be inactive during simulation. In the earlier version it was really cool, that i could switch between the axis, so i could move the for example the target dummy along different axis separately during simulation. Now I have to stop the simulation, select other axis, start again, and start everything again. It is really annoying. Is there a solution for this?
Thanking you in advance in this matter!
Regards,
David
General bugs(?) in version 3.3.2
Re: General bugs(?) in version 3.3.2
Hello David,
you are right, this will however change in next release, where the translation/rotation dialogs will be remodelled.
Thank you very much :) Then I don't search the solution.
