I found that there are no callbacks.* files in v_repExtOMPL (V-REP 3.4.0 rev1)
which seems to be necessary to compile. I just copied from previous version and found works fine,
but I'm just curious whether it is intended(I might be missing something).
Thanks in advance.
Missing 'callbacks.*' in the latest version
Re: Missing 'callbacks.*' in the latest version
thanks for the info. This is actually only needed if you don't have the stubs files in the source (or you want to add/change the API functions used by that plugin). We should soon put the code in a public repository..
Cheers.
Cheers.
