Headless mode
furious
Headless mode
Post by furious »
Vrep wont work in headless mode.
if i try
vrep.exe -s - BorisSim2bandgen.ttt
vrep opens and starts.
but when i try using the headless mode
vrep.exe -h -s - BorisSim2bandgen.ttt
C:\Program Files\V-REP3\V-REP_PRO\Warning: QT_DEVICE_PIXEL_RATIO is deprecated. Instead use:
    QT_AUTO_SCREEN_SCALE_FACTOR to enable platform plugin controlled per-screen factors.
    QT_SCREEN_SCALE_FACTORS to set per-screen factors.
    QT_SCALE_FACTOR to set the application global scale factor.
License file 'v_rep':
Add-on script 'vrepAddOnScript-clsConveyor.lua' was loaded.
Add-on script 'vrepAddOnScript-clsConveyorPTS.lua' was loaded.
Add-on script 'vrepAddOnScript-clsGenerator.lua' was loaded.
Add-on script 'vrepAddOnScript-clsInfoBar.lua' was loaded.
Add-on script 'vrepAddOnScript-constants.lua' was loaded.
Add-on script 'vrepAddOnScript-dozenafvoerband wachttijd.lua' was loaded.
Add-on script 'vrepAddOnScript-dozenafvoerband.lua' was loaded.
Add-on script 'vrepAddOnScript-fnMath.lua' was loaded.
Add-on script 'vrepAddOnScript-fnTimer.lua' was loaded.
Add-on script 'vrepAddOnScript-handafraap.lua' was loaded.
Add-on script 'vrepAddOnScript-LIBDIR.lua' was loaded.
Add-on script 'vrepAddOnScript-mainfullcase1 backup.lua' was loaded.
Add-on script 'vrepAddOnScript-mainfullcase1.lua' was loaded.
Simulator launched.
Plugin 'MeshCalc': loading...
Plugin 'Bwf': loading...
Plugin 'Bwf': load succeeded.
Plugin 'Cam': loading...
Plugin 'Cam': load succeeded.
Plugin 'CHAI3D': loading...
Plugin 'CHAI3D': load succeeded.
Plugin 'Collada': loading...
V-REP runs in headless mode. Cannot start 'Collada' plugin.
Plugin 'Collada': load failed (failed initialization).
Plugin 'CustomUI': loading...
Initialization failed, running in headless mode. Cannot start 'CustomUI' plugin.
Plugin 'CustomUI': load failed (failed initialization).
Plugin 'Joystick': loading...
Plugin 'Joystick': load succeeded.
Plugin 'K3': loading...
Plugin 'K3': load succeeded.
Plugin 'Mtb': loading...
Plugin 'Mtb': load succeeded.
Plugin 'OMPL': loading...
Plugin 'OpenMesh': loading...
Plugin 'PovRay': loading...
Plugin 'Qhull': loading...
Plugin 'RRS1': loading...
Plugin 'SDF': loading...
Plugin 'SDF': load succeeded.
Plugin 'Urdf-a': loading...
Plugin 'Urdf': loading...
V-REP runs in headless mode. Cannot start 'Urdf' plugin.
Plugin 'Urdf': load failed (failed initialization).
Plugin 'Vision': loading...
Plugin 'Wii': loading...
Plugin 'Wii': load succeeded.
Using the 'MeshCalc' plugin.
Engine version: 2.78
Plugin version: 9
Initialization successful.
Re: Headless mode
Edit by Coppelia: make sure to first read this topic about headless mode, this thread is old.
What do you mean with "won't work"?
The log you posted shows Initialization successful which suggests everything should be working fine.
furious
Re: Headless mode
Post by furious »
I Understand. i used
redirectStatusbarMsgToConsoleInHeadlessMode = true
in the usrset and found the problem.
I want to speed u my simulation. Do i need to change the
Time step
? who do i change it?
Re: Headless mode
those settings are part of a given scene. So edit the scene in the appropriate way (not in headless mode), save it. Then load it in headless mode.
