Runtime plugin reload
svepe
Post by svepe »
Hi Marc,
I write extensive plugins for V-REP which is an incremental process. When I make a change in the plugin I have to restart V-REP and reopen the scene by browsing to the file and these steps take time. Therefore, I have 2 requests:
1. Functionality which allows to reload plugin(s) while V-REP is running.
2. Add recent scenes menu
Thanks.
Re: Runtime plugin reload
Hello Svetlin,
you are right. The on-the-fly plugin load is on the todo-list. The recent scenes menu will be in next release (3.1.0).
svepe
Post by svepe »
Something that came to my mind and would be even better than the Recent menu is to be able to start v-rep from the terminal with the path to the scene which is to be simulated. If the scene which I need is robo_test.ttt then I would simply execute v-rep with "./vrep.sh /home/user/Scenes/robot_test.ttt".
That should already be working, but it seems there is a problem with the release 3.0.5 on Linux. Hopefully this will be fixed in next release (V-REP 3.1.0, to be released until the end of January 2014)
jacobhuesman
Post by jacobhuesman »
Was the runtime reload functionality ever implemented? I've been googling around and I can't find anything on the topic except for this post.
Thanks,
Jacob
Hello Jacob,
have a look at the simLoadModule API function.
jacobhuesman
That looks perfect. Thanks!
