Remote API Connection Timeouts
harrisonmg
Post by harrisonmg » 21 Feb 2018, 16:02
I am attempting to integrate the V-Rep remote api into a ROS node, but have been experiencing timeout issues.
I am using the remote server that is initiated when V-Rep starts, with the following parameters in the remoteApiConnections.txt file:
portIndex1_port             = 19997
portIndex1_debug            = false
portIndex1_syncSimTrigger   = true
I am connecting to the remote server from a ROS node written in Python in the following manner, which works reliably (as in I am able to receive a client id of 0):
import vrep
# configure server connection parameters
remote_server_address = '127.0.0.1' # loopback address for V-Rep and ROS run locally
remote_server_port = 19997 # set in vrep/remoteApiConnections.txt
wait_for_connection = True
dont_reconnect_on_disconnect = False
connecting_timeout = 2000 # 2 s timeout
comm_thread_cycle = 5 # 5 ms communication cycle
# attempt connection to the remote server
vrep.simxFinish(-1) # kill any other client connections
self.client_id = -1
while self.client_id == -1:
	self.client_id = vrep.simxStart(remote_server_address, remote_server_port, wait_for_connection,
									dont_reconnect_on_disconnect, connecting_timeout, comm_thread_cycle)
	if self.client_id == -1:
		rospy.logerr('Connection to V-Rep remote server failed. Retrying...')
rospy.logwarn('Connection to V-Rep remote server successful.')
After this, when I run the command simxGetPingTime like so,
vrep.simxGetPingTime(self.client_id)
I get a value of 5000 with a return code of 3, suggesting a timeout.
I also get return codes of 3 when attempting to get object handles, and a return code of 1 from the command simxStartSimulation.
This behavior persists if I start the server from a non-threaded child script in a scene, if I disable the synchronous trigger, and if I use a different port.
I am currently runnin V-Rep Pro Edu, Version 3.5.0 (rev. 0) 64bit (serialization version 21) (Qt Version 5.9.0, GCC)
I am confident my computer is powerful enough to run V-Rep at the default simulation step size of 50 ms and a very simple scene. What could perhaps be the issue?
Re: Remote API Connection Timeouts
Post by coppelia » 22 Feb 2018, 07:35
referring to my email earlier today, make sure that the simple remote API example run fine on your system. You can find those examples in programming/remoteApiBindings/python/python
harrisonmg
Post by harrisonmg » 22 Feb 2018, 16:37
When running simpleTest.py, the output is as follows before hanging for an indefinite amount of time.
Program started
Connected to remote API server
('Remote API function call returned with error code: ', 3)
I have also updated to V-Rep Version 3.5.0 Rev 1.
Thanks for your help,
Harrison
