Using -s and -h parameters crashes v-rep
lpitonakova
Post by lpitonakova »
I am trying to run a simulation in headless mode and start it automatically. This previously worked fine in V-REP 3.4., however, in 3.5., when I do e.g.
./vrep -h -s ~.../scenes/e-puckDemo.ttt
V-Rep crashes immediately with
Engine version: 2.78
Plugin version: 9
Initialization successful.
Error: signal 11:
0   libv_rep.dylib                      0x000000010c7ac4a1 _Z11_segHandleri + 33
1   libsystem_platform.dylib            0x00007fff5a1f1f5a _sigtramp + 26
2   ???                                 0x0000700000973990 0x0 + 123145312221584
3   liblua.5.1.dylib                    0x000000010d3cb595 luaD_callhook + 185
4   liblua.5.1.dylib                    0x000000010d3d43d2 luaV_execute + 215
5   liblua.5.1.dylib                    0x000000010d3cbc41 luaD_call + 98
6   liblua.5.1.dylib                    0x000000010d3cb344 luaD_rawrunprotected + 85
7   liblua.5.1.dylib                    0x000000010d3cbea5 luaD_pcall + 62
8   liblua.5.1.dylib                    0x000000010d3c81ec lua_pcall + 103
9   libv_rep.dylib                      0x000000010c738300 _ZN16CLuaScriptObject26_runThreadedChildScriptNowEv + 1552
QObject::~QObject: Timers cannot be stopped from another thread
QMutex: destroying locked mutex
This happens on both Mac and Linux.
lpitonakova
Re: Using -s and -h parameters crashes v-rep
Just tried to removing the -s parameter and instead writing a plugin that runs simStartSimulation() after the scene has loaded, with the same crash effect.
yes, you are right, we must have broken something for release 3.5.0...
We'll look into this and should then provide a revision release.
We found the problem. Thanks for mentioning it.
You can download correction libs. At some later point, we will release a new revision (V3.5.0 rev2+).
