Angular Velocity
zoebhosain
Angular Velocity
Post by zoebhosain »
I am creating simulation to understand robot workspace singularities. to aid my research i have a 2 link robot similar to the SCARA robot minus the prismatic joint for variation in Z direction.
I have been trying to get readings out, and i have been using a graph and exporting the data through a CSV.
I want to know the angular velocities of the links, and am looking for a solution to best help my problem.
thanking you in advance
Re: Angular Velocity
you can have your graph record time derivative values. Or you can directly select the graph data stream Joint: velocity. Or you can track the position of your joints inside of a child script, and do the derivation and export yourself from there.
zoebhosain
How do i track the position of the joints through a child script? I worked out the orientation of the joints(angles) and the values i am getting through the graph seems to be wrong.
thanks
Please give a concret example of what is not working, so that we can reproduce it. Otherwise it is difficult to help.
zoebhosain
I ended up fixing my model. sorry to have bothered you.
