Simulation fail calling sim.loadScene
vrepUser94
Post by vrepUser94 »
I am trying to load scenes by using the function "sim.loadScene", which i call in a customization script. I actually send a message via ROS to trigger the loading process. The problem is though, that the v-rep closes whenever this function is called.
Some of the last lines, that are printed in the terminal are (maybe it helps):
vrep: malloc.c:3722: _int_malloc: Assertion `(unsigned long) (size) >= (unsigned long) (nb)' failed.
./vrep.sh: line 33: 10029 Aborted (core dumped) "$dirname/$appname" "${PARAMETERS[@]}"
Does anyone have an idea how to solve this problem?
Thanks a lot
Re: Simulation fail calling sim.loadScene
you cannot use that function from a customization script, since that function will trigger first a scene erase before a scene load.
You can only use that function from an add-on (or from the sanbox script).
