Shared Memory problem when using 'simxCallScriptFunction'
sjames
Post by sjames »
I believe I have found a bug, but if I have missed something, then I apologise in advanced.
The issue is when calling 'simxCallScriptFunction' from python when using shared memory, and the function itself does a lot of computation.
The bug can be reproduced by simply having a script function like so:
test=function(inInts,inFloats,inStrings,inBuffer)
    for i=1,99999,1 do
        print(i)
    return {1},{},{},''
and then calling this from Python using 'simxCallScriptFunction'. The function on the Python side will hang; specifically when calling 'c_CallScriptFunction(...)'.
I have made sure that my port number <0, and have set a high negative timeout (e.g. -50000).
Note, that when I use port communication, it works fine. Perhaps there is timeout happening with shared memory?
Also of note, when I set 'doNotReconnectOnceDisconnected=False' when connected via shared memory, I get the following after the loop in the script finishes:
Connect (0): Failed to open the shared memory "/LocalVREP_REMOTE_API00001"
Thanks!
Re: Shared Memory problem when using 'simxCallScriptFunction'
Hello James,
indeed, there is something fishy...
Thanks for pointing this out.
can you tell me which platform you are running on?
sjames
Post by sjames »
I am running on Linux (Ubuntu 18.04).
Anything I can help with?
Also, on a related note, is it possible to support multiple instances when using shared memory? I.e. is it possible to allocate a portion of the memory, so that another instance can have another portion?
Thanks,
normally you can have several shared memory remote API clients by specifying each time a different, negative port number (i.e. similar to creating several clients when using socket communication).
