Save Greyscale Image from Vision Sensor
mirovoellmy
Post by mirovoellmy » 18 Feb 2019, 13:20
I'm trying to record a greyscale vision sensor and save some images to drive using sim.saveImage().
The documentation describes that the the function can only handle rgb and rgbd images. Did I miss something or do I have to manually convert my greyscale [res_x * res_y] image to a rgb [res_x * res_y * 3] image everytime I want to save an image?
If yes, it would be nice to have an option in the saveImage() function so it can also save grayscale images. :)
Miro
Re: Save Greyscale Image from Vision Sensor
Post by coppelia » 20 Feb 2019, 13:43
you can use sim.transformBuffer for that:
rgbImage=sim.transformBuffer(greyImage,sim.buffer_uint8,1,0,sim.buffer_uint8rgb)
