VREP randomly cannot find remoteApiCommandServer.lua or any related .so libraries
agsdyson
Re: VREP randomly cannot find remoteApiCommandServer.lua or any related .so libraries
Post by agsdyson »
I have not tested it without start+stop or dummy creation. I created a dummy so that I could visually check that the program was still running. In my real code I don't create a dummy, but create links for a robot and it still crashes.
Does the example crash on your computer?
agsdyson
Post by agsdyson »
I ran without simulation start/stop or dummy creation and it crashed after 2500 seconds.
the problem seems to be linked to the fact that several instances of V-REP are running in parallel... since I cannot make V-REP crash with your example with a single instance...
agsdyson
Post by agsdyson »
It crashes for me when I only run a single instance
clientID 0
it 3222 time: 1650.76560903
clientID 0
*** buffer overflow detected ***: /home/ags/python_modules/workspaceAnalysis/pyvrep/pyvrep/VREP/vrep terminated
======= Backtrace: =========
/lib/x86_64-linux-gnu/libc.so.6(+0x777e5)[0x7fe646a0e7e5]
/lib/x86_64-linux-gnu/libc.so.6(__fortify_fail+0x5c)[0x7fe646ab015c]
/lib/x86_64-linux-gnu/libc.so.6(+0x117160)[0x7fe646aae160]
/lib/x86_64-linux-gnu/libc.so.6(+0x1190a7)[0x7fe646ab00a7]
/home/ags/python_modules/workspaceAnalysis/pyvrep/pyvrep/VREP/libv_repExtRemoteApi.so(_ZN13CInConnection15connectToClientEv+0x16b)[0x7fe6071c402b]
/home/ags/python_modules/workspaceAnalysis/pyvrep/pyvrep/VREP/libv_repExtRemoteApi.so(_ZN11CSimxSocket4_runEv+0x111)[0x7fe6071cf891]
/lib/x86_64-linux-gnu/libpthread.so.0(+0x76ba)[0x7fe6464786ba]
/lib/x86_64-linux-gnu/libc.so.6(clone+0x6d)[0x7fe646a9e41d]
======= Memory map: ========
./vrep.sh: line 33: 8562 Aborted "$dirname/$appname" "${PARAMETERS[@]}"
agsdyson
Post by agsdyson »
Do you have any idea of what is causing the crash when it is run in parallel?
We haven't yet had time to check that out. But it seems that there could be a memory leak or some handles not closed in function inConnection::connectToClient if file inConnection.cpp of v_repExtRemoteApi plugin:
#include "inConnection.h"
#include "simxUtils.h"
#define HEADER_LENGTH 6 // WORD0=1 (to detect endianness), WORD1=packetSize, WORD2=packetsLeftToRead
#define SOCKET_TIMEOUT_READ 10000 // in ms
#define TCP_SEVER_CONNECT_TIMEOUT_USEC (5000*1000)
#if defined (__linux) || defined (__APPLE__)
#include <fcntl.h>      /* Defines O_ * constants */
#include <sys/stat.h>   /* Defines mode constants */
#include <sys/mman.h>
#include <stdio.h>
#endif
CInConnection::CInConnection(int theConnectionPort,int maxPacketSize,bool newVersion)
    _newVersion=newVersion;
    _otherSideIsBigEndian=false;
    _connected=false;
    _leaveConnectionWait=false;
    _maxPacketSize=maxPacketSize;
    _usingSharedMem=(theConnectionPort<0);
    if (_usingSharedMem)
    { // shared memory routines are courtesy of Benjamin Navarro
		theConnectionPort=-theConnectionPort;
		_socketConnectionPort=theConnectionPort;
		set_shared_memory_name(&_shared_memory_info, _socketConnectionPort);
		set_shared_memory_size(&_shared_memory_info, _maxPacketSize+20);
		if(create_shared_memory(&_shared_memory_info))
			if(map_shared_memory(&_shared_memory_info))
				_shared_memory_info.buffer[0] = 0; // not yet connected
				((int*)(_shared_memory_info.buffer+1))[0] = _maxPacketSize;
				fprintf(stderr, "Failed to map the shared memory \"%s\"\n", _shared_memory_info.name);
				destroy_shared_memory(&_shared_memory_info);
			fprintf(stderr, "Failed to create the shared memory \"%s\"\n", _shared_memory_info.name);
        if (_newVersion)
            _listening = false;
            memset(&_address, 0, sizeof(struct sockaddr_in));
            _address.sin_family = AF_INET;
            _address.sin_addr.s_addr = INADDR_ANY;
            _address.sin_port = htons((u_short)theConnectionPort);
            _local_socket=-1;
            _accepted_socket=-1;
            memset(&_socketLocal,0,sizeof(struct sockaddr_in));
                _socketServer=-1;
                _socketClient=-1;
            #endif /* __linux || __APPLE__ */
CInConnection::~CInConnection()
    { // Shared memory routines are courtesy of Benjamin Navarro
		if(unmap_shared_memory(&_shared_memory_info) == false) {
			fprintf(stderr, "Failed to unmap the shared memory \"%s\"\n", _shared_memory_info.name);
#endif
		if(destroy_shared_memory(&_shared_memory_info) == false) {
			fprintf(stderr, "Failed to destroy the shared memory \"%s\"\n", _shared_memory_info.name);
        if (_newVersion)
            #ifdef _WIN32
                if (_local_socket != -1)
                    closesocket(_local_socket);
                if (_accepted_socket != -1)
                    shutdown(_accepted_socket, 2); //SD_BOTH
                WSACleanup();
            #endif /* _WIN32 */
                if (_local_socket !=-1)
                    close(_local_socket);
                if (_accepted_socket !=-1)
                    close(_accepted_socket);
            if (_connected)
                #ifdef _WIN32
                    shutdown(_socketClient,2); //SD_BOTH
                    closesocket(_socketServer);
                    WSACleanup();
                #endif /* _WIN32 */
                    if (_socketServer!=-1)
                        close(_socketServer);
                    if (_socketClient!=-1)
                        close(_socketClient);
bool CInConnection::connectToClient()
    if (_leaveConnectionWait)
        return(false);
		if(is_valid_shared_memory_handle(&_shared_memory_info))
			while (!_leaveConnectionWait)
				bool connected = _shared_memory_info.buffer[0] == 1;
				if(connected)
					break;
				Sleep(1);
			_connected = true;
			return true;
			return false;
        if (_newVersion)
            // Connect to the port only one time in the beginning
            if (_listening == false)
                #ifdef _WIN32
                    if (WSAStartup(0x101, &_socketWsaData)!= 0)
                        return(false);
                #endif
                _local_socket = socket(AF_INET, SOCK_STREAM, 0);
                if (_local_socket == INVALID_SOCKET)
                    return(false);
                if (bind(_local_socket, (struct sockaddr*)&_address, sizeof(_address))!= 0)
                    return(false);
                if (listen(_local_socket, 10)!= 0)
                    return(false);
                FD_ZERO(&_read_fd);
                FD_SET(_local_socket, &_read_fd);
                _listening = true;
            // If a clients has connect request, accept it.
            if (!_connected)
                //  Timeout  specification;  must  be  reset  every  time  select()  is  called
                struct timeval  selTimeout;     //  Timeout  for  select()
                selTimeout.tv_sec = 0;          //  Set  timeout  (secs.)
                selTimeout.tv_usec = TCP_SEVER_CONNECT_TIMEOUT_USEC;
                #ifdef _WIN32
                    select(0, &_read_fd, NULL, NULL, &selTimeout);
                #else
                    select(_local_socket+1, &_read_fd, NULL, NULL, &selTimeout);
                #endif
                if (!FD_ISSET(_local_socket, &_read_fd))
                    return (false);
                // 2. accept client:
                struct sockaddr_in from;
                int fromlen=sizeof(from);
                _accepted_socket = accept(_local_socket,(struct sockaddr*) &from, (_socklen *) &fromlen);
                _socketConnectedMachineIP = inet_ntoa(from.sin_addr);
                _socketTimeOut.tv_sec = 1; // 1 second max between successive receive for the same packet
                _socketTimeOut.tv_usec = 0;
                // Following since 13/12/2013:
                #ifdef _WIN32
                    int to = 2000;
                    setsockopt(_accepted_socket, SOL_SOCKET, SO_RCVTIMEO,(char*)&to,sizeof(int));
                    setsockopt(_accepted_socket, SOL_SOCKET, SO_SNDTIMEO,(char*)&to,sizeof(int));
                    int yes = 1;
                    setsockopt(_accepted_socket, SOL_SOCKET, SO_REUSEADDR,(char*)&yes, sizeof(int));
//                  to = 3000000;
//                  setsockopt(_accepted_socket, SOL_SOCKET, SO_RCVBUF,(char*)&to,sizeof(int));
//                  setsockopt(_accepted_socket, SOL_SOCKET, SO_SNDBUF,(char*)&to,sizeof(int));
                #else
                    struct timeval tv;
                    tv.tv_sec = 2; // from 0 to 2 on 28/6/2014. Thanks to Ulrich Schwesinger for catching this
                    tv.tv_usec = 2000;
                    setsockopt(_accepted_socket, SOL_SOCKET, SO_RCVTIMEO,(struct timeval *)&tv,sizeof(struct timeval));
                    setsockopt(_accepted_socket, SOL_SOCKET, SO_SNDTIMEO,(struct timeval *)&tv,sizeof(struct timeval));
                    int yes = 1;
                    setsockopt(_accepted_socket, SOL_SOCKET, SO_REUSEADDR, &yes, sizeof(int));
                #endif
                _connected = true;
                return(true);
            return(false);
            #ifdef _WIN32
                // 1. connect to port:
                if (WSAStartup(0x101,&_socketWsaData)!=0)
                    return(false);   // WSAStartup failed.
            #endif /* _WIN32 */
            _socketLocal.sin_family=AF_INET;
            _socketLocal.sin_addr.s_addr=INADDR_ANY;
            _socketLocal.sin_port=htons((u_short)_socketConnectionPort);
            _socketServer=socket(AF_INET,SOCK_STREAM,0);
            if (_socketServer==INVALID_SOCKET)
                return(false); // socket failed.
            if (bind(_socketServer,(struct sockaddr*)&_socketLocal,sizeof(_socketLocal))!=0)
                return(false); // bind failed.
            if (listen(_socketServer,10)!=0)
                return(false); // listen failed.
            _socketClient=accept(_socketServer,(struct sockaddr*) &from, (_socklen *) &fromlen);
            _socketConnectedMachineIP=inet_ntoa(from.sin_addr);
            _socketTimeOut.tv_sec=1; // 1 second max between successive receive for the same packet
            _socketTimeOut.tv_usec=0;
            FD_ZERO(&_socketTheSet);
            FD_SET(_socketClient,&_socketTheSet);
            #ifdef _WIN32
                int to=2000;
                setsockopt(_socketClient, SOL_SOCKET, SO_RCVTIMEO,(char*)&to,sizeof(int));
                setsockopt(_socketClient, SOL_SOCKET, SO_SNDTIMEO,(char*)&to,sizeof(int));
                int yes = 1;
                setsockopt(_socketClient, SOL_SOCKET, SO_REUSEADDR,(char*)&yes, sizeof(int));
            #else
                struct timeval tv;
                tv.tv_usec = 2000;
                setsockopt(_socketClient, SOL_SOCKET, SO_RCVTIMEO,(struct timeval *)&tv,sizeof(struct timeval));
                setsockopt(_socketClient, SOL_SOCKET, SO_SNDTIMEO,(struct timeval *)&tv,sizeof(struct timeval));
                int yes = 1;
                setsockopt(_socketClient, SOL_SOCKET, SO_REUSEADDR, &yes, sizeof(int));
            #endif
            _connected=true;
            return(true);
void CInConnection::stopWaitingForConnection()
{ // Make a fake connection to this socket, to unblock it (the thread might be trapped in the "accept" function)
    _leaveConnectionWait=true;
char* CInConnection::receiveMessage(int& messageSize)
{ // Returns the data size if >0, 0=we had a read time out, -1=we have an error
    if (!_connected)
        messageSize=-1; // error
        return(NULL);
		return(_receive_sharedMem(messageSize));
        std::vector<char> receivedData;
        while (true)
            std::vector<char> inDat;
            int result=_receiveSimplePacket(inDat);
            if (result<0)
                messageSize=result+1; // error or read time-out
                return(NULL);
            receivedData.insert(receivedData.end(),inDat.begin(),inDat.end());
            if (result==0)
            { // success
                messageSize=int(receivedData.size());
                char* retBuff=new char[messageSize];
                for (int i=0;i<messageSize;i++)
                    retBuff[i]=receivedData[i];
                return(retBuff);
bool CInConnection::replyToReceivedMessage(char* message,int messageSize)
    if (!_connected)
        return(false);
    if (messageSize==0)
        return(false);
		return(_send_sharedMem(message,messageSize));
        // In Following we make sure we don't send too big packets (we might send the data in several packets)
        int packetCount=0;
        int s=messageSize;
        while (s!=0)
            packetCount++;
            if (s>_maxPacketSize-HEADER_LENGTH)
                s-=_maxPacketSize-HEADER_LENGTH;
                s=0;
        s=messageSize;
        int ptr=0;
        while (s!=0)
            packetCount--;
            int sizeToSend=s;
                sizeToSend=_maxPacketSize-HEADER_LENGTH;
            s-=sizeToSend;
            if (!_sendSimplePacket(message+ptr,sizeToSend,packetCount))
                return(false);
            ptr+=sizeToSend;
    return(true);
std::string CInConnection::getConnectedMachineIP()
        return("");
        if (!_connected)
            return("NONE (reception line is not open)");
        return(_socketConnectedMachineIP);
bool CInConnection::isOtherSideBigEndian()
    return(_otherSideIsBigEndian);
bool CInConnection::_sendSimplePacket(char* packet,int packetLength,WORD packetsLeft)
    if (packetLength==0)
        return(false);
    // Insert the header:
    WORD s=WORD(packetLength);
    char header[HEADER_LENGTH];
    ((WORD*)header)[0]=1; // Allows to detect endianness on the other side
    ((WORD*)header)[1]=littleEndianShortConversion(s,_otherSideIsBigEndian);
    ((WORD*)header)[2]=littleEndianShortConversion(packetsLeft,_otherSideIsBigEndian);
    std::vector<char> toSend;
    for (int i=0;i<HEADER_LENGTH;i++)
        toSend.push_back(header[i]);
    for (int i=0;i<packetLength;i++)
        toSend.push_back(packet[i]);
    // Send the packet:
    if (_newVersion)
        return(send(_accepted_socket,&toSend[0],packetLength+HEADER_LENGTH,0)==packetLength+HEADER_LENGTH);
        return(send(_socketClient,&toSend[0],packetLength+HEADER_LENGTH,0)==packetLength+HEADER_LENGTH);
int CInConnection::_receiveSimplePacket(std::vector<char>& packet)
    if (_newVersion)
        if (_connected)
            //1. Read the header and packet size:
            char headerAndSize[HEADER_LENGTH];
            int totalReceived=0;
            DWORD startT=getTimeInMs();
            while(totalReceived!=HEADER_LENGTH)
                int nb=recv(_accepted_socket,headerAndSize+totalReceived,HEADER_LENGTH-totalReceived,0);
                if (nb<1)
                    break;
                totalReceived+=nb;
                if (getTimeDiffInMs(startT)>SOCKET_TIMEOUT_READ)
                    break;
            // 2. Check if the header is consistent:
            if (totalReceived!=HEADER_LENGTH)
                return(-2); // Error reading
            _otherSideIsBigEndian=(((WORD*)headerAndSize)[0]!=1);
            WORD dataLength=littleEndianShortConversion(((WORD*)headerAndSize)[1],_otherSideIsBigEndian);
            // 3. Read the data with correct length:
            packet.clear();
            packet.resize(dataLength,0);
            totalReceived=0;
            while(totalReceived!=dataLength)
                int nb=recv(_accepted_socket,&packet[0]+totalReceived,dataLength-totalReceived,0);
                if (nb<1)
                    break;
                totalReceived+=nb;
                    break;
            if (totalReceived!=dataLength)
                return(-2); // wrong size or nothing received
            return(int(littleEndianShortConversion(((WORD*)headerAndSize)[2],_otherSideIsBigEndian)));
        return(-1);
        _socketTimeOut.tv_sec=10; // 1 second max between successive receive for the same packet
        #ifdef _WIN32
            int selectResult=select(0,&_socketTheSet,NULL,NULL,&_socketTimeOut);
        #else
            int selectResult=select(_socketClient+1, &_socketTheSet,NULL,NULL,&_socketTimeOut);
        #endif
        if (selectResult==1)
                int nb=recv(_socketClient,headerAndSize+totalReceived,HEADER_LENGTH-totalReceived,0);
                if (nb<1)
                    break;
                totalReceived+=nb;
                    break;
            packet.clear();
            totalReceived=0;
                int nb=recv(_socketClient,&packet[0]+totalReceived,dataLength-totalReceived,0);
                if (nb<1)
                    break;
                totalReceived+=nb;
                    break;
        if (selectResult==0)
            return(-1);
        return(-2);
bool CInConnection::_send_sharedMem(const char* data,int dataLength)
	int initDataLength=dataLength;
	if (dataLength==0)
		return(false);
	if (_shared_memory_info.buffer[0] == 1)
	{     // ok still connected
		int off=0;
		while (dataLength>0)
            // Wait for previous data to be gone:
			while (_shared_memory_info.buffer[5]!=0)
				if (getTimeDiffInMs(startT)>1000)
					return(false);
            // ok, we can send the data:
			if (dataLength<=_maxPacketSize)
			{     // we can send the data in one shot:
				memcpy(_shared_memory_info.buffer+20,data+off,dataLength);
				((int*)(_shared_memory_info.buffer+6))[0]=dataLength;
				((int*)(_shared_memory_info.buffer+6))[1]=20;
				((int*)(_shared_memory_info.buffer+6))[2]=initDataLength;
				dataLength=0;
			{     // just send a smaller part first:
				memcpy(_shared_memory_info.buffer+20,data+off,_maxPacketSize);
				((int*)(_shared_memory_info.buffer+6))[0]=_maxPacketSize;
				dataLength-=(_maxPacketSize);
				off+=(_maxPacketSize);
			_shared_memory_info.buffer[5]=2;     /* server has something to send! */
        return(true);
    return(false);
char* CInConnection::_receive_sharedMem(int& dataLength)
	int retDataOff=0;
	char* retData=0;
	int totalLength=-1;
	dataLength=0;
	if (_shared_memory_info.buffer[0]==1)
		while (retDataOff!=totalLength)
			// Wait for data:
			while (_shared_memory_info.buffer[5]!=1)
					return(0);
			// ok, data is there!
			// Read the data with correct length:
			int l=((int*)(_shared_memory_info.buffer+6))[0];
			int off=((int*)(_shared_memory_info.buffer+6))[1];
			totalLength=((int*)(_shared_memory_info.buffer+6))[2];
			if (retData==0)
				retData=new char[totalLength];
			memcpy(retData+retDataOff,_shared_memory_info.buffer+off,l);
			retDataOff=retDataOff+l;
			// Tell the other side we have read that part and additional parts could be sent (if present):
			_shared_memory_info.buffer[5]=0;
	dataLength=retDataOff;
	return(retData);
The problem seems to be identical to this post.
agsdyson
Post by agsdyson »
Thanks,
For the moment I will try to minimise the number of times I connect and disconnect so that it takes longer to crash.
Can you try following?
In the V-REP folder, you'll find a file named remoteApiConnections.txt. In there, append following line:
useAlternateSocketRoutines  = true
Let me know if that works.
agsdyson
Post by agsdyson »
I have not run it for long enough yet to see if it solves the main problem, but it causes other problems after 1 iteration of my algorithm because the connection time because highly unstable.
Spawn 7 instances of vrep
launch the optimiser that connects to those 7 instances and computes a function in vrep.
The function takes approximately the same time to complete for each vrep instance
When all the functions are complete the optimiser works out the next set of parameters to test in the vrep function.
Reconnect to the vrep instances and compute the function
With useAlternateSocketRoutines = false, this works (except for the 1600 second problem).
With useAlternateSocketRoutines = true, when the first set of function calls are finished, the optimiser attempts reconnects to
the existing vrep instances. However, the second time around some of the instances take much longer to connect than others. This means that most of the time 6 of the vrep instances are waiting around doing nothing because they have finished computing the function while they wait for the 7th to connect. The connection time is several times longer than the time to compute the function.
I'll run it for a while to see if it solves the first connection problem, but as is this doesn't really solve my problem.
agsdyson
Post by agsdyson »
It has been running for 1:20 hr so it looks like this solves the connection issue.
I will leave this running overnight and report back tomorrow.
