V-REP crash (running several instances of V-REP with several remote API clients)
Re: V-REP crash (running several instances of V-REP with several remote API clients)
Uli_v wrote: 25 Jun 2019, 16:56 How do I compile the plugin in debug mode?
If it is based on CMake, then pass option -DCMAKE_BUILD_TYPE=Debug to cmake.
If it is based on QMake, then pass CONFIG+=debug to qmake.
Uli_v
Post by Uli_v »
I git cloned: https://github.com/CoppeliaRobotics/v_repExtRemoteApi
I then I tried:
cmake -DCMAKE_BUILD_TYPE=Debug
But there is no CMakeLists.txt.
What are all the steps necessary to build/cmake the RemoteApi plugin? Thanks.
Uli_v wrote: 26 Jun 2019, 16:17 I git cloned: https://github.com/CoppeliaRobotics/v_repExtRemoteApi
I then I tried:
That's a QMake based plugin
Uli_v
Post by Uli_v »
So what are the steps to make this via qmake?
