How to make the quadricopter fly to a specified coordinate?
wode
Post by wode »
I use five native mobile robots: quadricopters in my scene. And i try to make the quadricopters fly to a specified coordinate but i cannot do this. I only can control the direction and velocity of quadricopter. However, when i want the quadricopter fly to some specified positions, i cannot get the direction and velocity of quadricopter in real time.
Then i try to set the position of the quadricopter's Quadricopter_target to the specified coordinate, but when simulation starts, Quadricopter_target's position restored.
So how can i make the quadricopter fly to a specified coordinate?
Thanks for your reply.
Re: How to make the quadricopter fly to a specified coordinate?
wode wrote: 25 Dec 2019, 03:27 Then i try to set the position of the quadricopter's Quadricopter_target to the specified coordinate, but when simulation starts, Quadricopter_target's position restored.
That's how it is meant to work: you set the target position by moving Quadricopter_target object. It should work also if setting that position before simulation start.
However you can modify the embedded script of Quadricopter to make it behave as you wish.
