Remote API calls getting slower and slower
JoakimMagnusson
Post by JoakimMagnusson »
I have a problem that my python remote API calls are getting slower and slower whenever I run a simulation.
I run in synchronous mode.
For get handles calls I'm doing like this:
errorCode, handle = vrep.simxGetObjectHandle(self.clientID, string, vrep.simx_opmode_blocking)
For get variable calls I'm first initiating with this call:
vrep.simxGetObjectPosition(self.clientID, self.hexapod, -1, vrep.simx_opmode_streaming)
and then during the rest of the simulation I'm doing like this:
while (vrep.simxGetConnectionId(self.clientID) != -1):
			[result,position]=vrep.simxGetObjectPosition(self.clientID, self.hexapod, -1, vrep.simx_opmode_buffer)
			if (result==vrep.simx_return_ok):
 				return position
Worth mentioning is also that I resets my simulation model (of a robot) several times during the simulation. In my reset function, I'm doing like this for all get variable calls:
vrep.simxGetObjectPosition(self.clientID, self.hexapod, -1, vrep.simx_opmode_discontinue)
Then I remove and reload my model (In order to move it to it's starting position). After this I initiate all get variable calls with simx_opmode_streaming again.
For set variable calls I'm using the simx_opmode_oneshot or simx_opmode_oneshot_wait operators.
I thought doing like this would prevent the simulation from slowing down but it still does. How do I know it's getting slower? I'm timing my simxSynchronousTrigger call which are getting longer and longer during simulation.
Is there something else to have in mind in order to not get any memory leaks or whatever is causing this issue?
I can show more code if necessary but I tried to extract the important parts and thought it would be more helpful than just printing all my code.
JoakimMagnusson
Re: Remote API calls getting slower and slower
I tried to just restart the simulation instead of removing and reloading my robot model, this made the problem disappear. Restarting the simulation is slower than reloading the model and I would like to use the fastest option. So I still wonder why this problem occur, do I reload the model in the wrong way maybe?
I am not sure due to what reason the simulation gets slower. Is it the simulation itself, or the remote API?
My first guess was that it could be the remote API, where streaming data is not properly discontinued. But it seems you are discontinuing streaming commands, so that is not the reason. Can you notice a memory usage increase that is more than what you expect?
Maybe when remove your model, not everything is removed (e.g. a collision checking object) and you end-up with many duplicates? (normally this is automatically handled when removing the model, but specific collision objects are persistent)
JonasMuegge
Post by JonasMuegge »
Hi, is there a solution to this problem, cause I have got the same.
In my project I connect from a julia script via python b0 remote api to a simulation.
In a test script I only connect and do some basic movements and call some functions in the simulation
the connection is build up here and works fine:
	b0RemoteApi=PyCall.pyimport("b0RemoteApi")
	client=b0RemoteApi.RemoteApiClient("b0RemoteApi_V-REP-addOn","b0RemoteApiAddOn")
	client.simxSynchronous(true)
	topicPub = client.simxDefaultPublisher()
	topicSubStart = client.simxDefaultSubscriber(callbackFunStart)
	topicSubStop = client.simxDefaultSubscriber(callbackFunDone)
Then I repeat the following code to move a human model in a circle:
	client.simxStartSimulation(topicPub)
	client.simxCallScriptFunction("selectWalkingDirection@Bill","sim.scripttype_customizationscript",walkingDirection,topicPub)
	client.simxCallScriptFunction("selectUpperBodyMotion@Bill","sim.scripttype_customizationscript",bend,topicPub)
	for i=1:timesteps
		client.simxGetSimulationStepStarted(topicSubStart)
		client.simxGetSimulationStepDone(topicSubStop)
		client.simxSynchronousTrigger()
		client.simxSpinOnce()
	client.simxPauseSimulation(topicPub)
The elapse time for this code section gets higher and higher. It starts at 0.5 seconds and increases. After 300 executions it takes around 2 seconds and after 500 executions around 3 seconds.
Hope there is a solution, Thanks.
thanks for bringing this again to our attention. Would it be possible to create a very simple example that illustrates the slowdown? The simpler, the easier it would be for us to identify the source of the problem. Best of course would be if that can be reproduced with an empty scene, since this would very probably indicate that the slowdown is really caused by the B0-based remote API.
JonasMuegge
I deleted all unnecessary code from my project. Now it only connects via b0remoteApi, starts simulation, stops simulation, and spins. Here the code from the script:
VRPInterface=include("VREPInterface.jl")
for a = 1:100
    client,topicPub,topicSubStart,topicSubStop = VREPInterface.connectToVREP() #,collisionHandle,distanceHandle,robotHandle,humanHandle=VREPInterface.connectToVREP()
    for i = 1:1000
        @info "step number " (a-1)*100 + i
        #starttime = Dates.t
        step = mod(i,2)
        @info @elapsed VREPInterface.executeAction(step,0, client, 2, topicPub, topicSubStart, topicSubStop)
        # distCalcReturn=client.simxReadDistance(distanceHandle,client.simxServiceCall())
        # success,v_linear,v_angular=client.simxGetObjectVelocity(robotHandle,client.simxServiceCall())
        # collisionReturn = client.simxReadCollision(collisionHandle,client.simxServiceCall())
        # velocityReturn = client.simxGetObjectVelocity(robotHandle,client.simxServiceCall())
        # positionReturn = client.simxGetObjectPosition(humanHandle, -1, client.simxServiceCall())
    #client.__exit__(client)
And the code for the VREPInterface,jl module
module VREPInterface
using PyCall
export connect_to_vrep
function connectToVREP()
	@info pwd()
	pushfirst!(PyCall.PyVector(PyCall.pyimport("sys")."path"), "")
	return client,topicPub,topicSubStart,topicSubStop #,collisionHandle,distanceHandle,robotHandle,humanHandle
function callbackFunStart(msg)
	print("simulation Step Started")
function callbackFunDone(msg)
	print("Simulation Step Done")
# communication to simulation VREP, setting the motion and executing it
function executeAction(walkingDirection,bend,client,timesteps,topicPub,topicSubStart,topicSubStop)
	#client.simxCallScriptFunction("selectWalkingDirection@Bill","sim.scripttype_customizationscript",walkingDirection,topicPub)
	#client.simxCallScriptFunction("selectUpperBodyMotion@Bill","sim.scripttype_customizationscript",bend,topicPub)
	for i=1:timesteps
Currently I am using julia 1.3.1 and https://github.com/JuliaPy/PyCall.jl to use python in it.
Is this ok for you?
Running the above code I get the following outcome.
As you can see the elapse time still increases.
Simulation Step Donesimulation Step StartedSimulation Step Donesimulation Step Started[ Info: 2.006505101
┌ Info: step number
└   (a - 1) * 100 + i = 329
Simulation Step Donesimulation Step StartedSimulation Step Donesimulation Step Started[ Info: 1.993775999
┌ Info: step number
└   (a - 1) * 100 + i = 330
Simulation Step Donesimulation Step StartedSimulation Step Donesimulation Step Started[ Info: 2.100352901
┌ Info: step number
└   (a - 1) * 100 + i = 331
Simulation Step Donesimulation Step StartedSimulation Step Donesimulation Step Started[ Info: 1.9877204
┌ Info: step number
└   (a - 1) * 100 + i = 332
Simulation Step Donesimulation Step StartedSimulation Step Donesimulation Step Started[ Info: 2.013947899
┌ Info: step number
└   (a - 1) * 100 + i = 333
Simulation Step Donesimulation Step StartedSimulation Step Donesimulation Step Started[ Info: 1.864915399
┌ Info: step number
└   (a - 1) * 100 + i = 670
Simulation Step Donesimulation Step StartedSimulation Step Donesimulation Step Started[ Info: 4.5439249
┌ Info: step number
└   (a - 1) * 100 + i = 671
Simulation Step Donesimulation Step StartedSimulation Step Donesimulation Step Started[ Info: 3.7425493
┌ Info: step number
└   (a - 1) * 100 + i = 672
Simulation Step Donesimulation Step StartedSimulation Step Donesimulation Step Started[ Info: 4.9993546
┌ Info: step number
└   (a - 1) * 100 + i = 673
Simulation Step Donesimulation Step StartedSimulation Step Donesimulation Step Started[ Info: 4.3945773
┌ Info: step number
└   (a - 1) * 100 + i = 674
Simulation Step Donesimulation Step StartedSimulation Step Donesimulation Step Started[ Info: 4.9315689
Hello Jonas,
Thanks for the effort... I would however really appreciate if you could simplify your example to use a simple Python script as client, since otherwise things are more difficult for use to set-up and also identify the source of problem.
JonasMuegge
All right.
import b0RemoteApi
import time
with b0RemoteApi.RemoteApiClient('b0RemoteApi_pythonClient','b0RemoteApiAddOn',60) as client:
    def callb(msg):
        #print(msg)
        None
    def action():
        for i in range(4):
    client.simxAddStatusbarMessage('Hello',client.simxDefaultPublisher())
    topicSubStart = client.simxDefaultSubscriber(callb)
    topicSubStop = client.simxDefaultSubscriber(callb)
    for i in range(1000):
        print(i)
        starttime = time.time()
        action()
        endtime = time.time()
        print(endtime - starttime)
Hello Jonas,
in your example, you are actually subscribing a new message in each simulation step... why? You should call for instance:
only once to register that subscriber. If you do it more than once, you'll have everytime one additional subscriber enabled.
Additionally, you start simulation but never stop it. And when stopping it, beware that it will take a few additional simulation steps until it has stopped. So slightly modifying your example to following doesn't have the delay anymore:
import b0RemoteApi
import time
    def callb(msg):
        print(msg)
        None
    def action():
        for i in range(4):
        client.simxStopSimulation(topicPub)
        for i in range(4):
        print(i)
        action()
Of course you could register a new subscriber in each new simulation run. But then you should remove it again at the end of the simulation. Taking the demo scene synchronousImageTransmissionViaRemoteApi.ttt, you can test it with following code:
import b0RemoteApi
import time
with b0RemoteApi.RemoteApiClient('b0RemoteApi_pythonClient','b0RemoteApi') as client:
    client.doNextStep=True
    client.runInSynchronousMode=True
    def simulationStepStarted(msg):
        simTime=msg[1][b'simulationTime'];
        #print('Simulation step started. Simulation time: ',simTime)
    def simulationStepDone(msg):
        #print('Simulation step done. Simulation time: ',simTime);
    def imageCallback(msg):
        #print('Received image.',msg[1])
        client.simxSetVisionSensorImage(passiveVisionSensorHandle[1],False,msg[2],client.simxDefaultPublisher())
    def stepSimulation():
        if client.runInSynchronousMode:
            while not client.doNextStep:
            client.doNextStep=False
        else:
    visionSensorHandle=client.simxGetObjectHandle('VisionSensor',client.simxServiceCall())
    passiveVisionSensorHandle=client.simxGetObjectHandle('PassiveVisionSensor',client.simxServiceCall())
        client.simxSynchronous(True)
    for y in range(100):
        sub1=client.simxDefaultSubscriber(imageCallback)
        client.simxGetVisionSensorImage(visionSensorHandle[1],False,sub1)
        sub2=client.simxDefaultSubscriber(simulationStepStarted)
        client.simxGetSimulationStepStarted(sub2);
        sub3=client.simxDefaultSubscriber(simulationStepDone)
        client.simxGetSimulationStepDone(sub3);
        client.simxStartSimulation(client.simxDefaultPublisher())
        startTime=time.time()
        for x in range(4):
            stepSimulation()
        client.simxStopSimulation(client.simxDefaultPublisher())
        client.simxRemoveSubscriber(sub3)
        client.simxRemoveSubscriber(sub2)
        client.simxRemoveSubscriber(sub1)
JonasMuegge
Thanks a lot for the answer, it helped me a lot. Now I don't have any issues concerning time.
Is there a definite number of timesteps for coppeliasim to stop the simulation after calling simxStopSimulation()?
