Building V-Rep 3.0.5c
BenjaminV
Post by BenjaminV »
I tried to compile the last version of V-REP but it fails!
First I have issue with uint variables used in sourceCode/textures/stb_image.c which I have solved with some typedef
Then I have a second issue which is a bit more problematic :
In file included from sourceCode/interfaces/v_rep.cpp:30:0:
sourceCode/interfaces/v_rep.h:34:33: fatal error: v_rep_funcUndefines.h : No such file or directory
Can you help me?
BTW : I'm on Ubuntu 12.04 with Qt5.1.1 and QScintilla2.8
Ben
Re: Building V-Rep 3.0.5c
Hello Ben,
you are right, the last release has a few problems. You can comment the line that includes v_rep_funcUndefines.h. Probably a few similar occurences.
That happens, because the source code went through a preprocessing stage, that stripped it from many things that are not needed. This should slowly be removed with time, until the source code will be put to a public repository.
BenjaminV
Post by BenjaminV »
The thing is I tried that too but I had an other issue
‘_prepareCustomGuiEvent_noDirectEventProccessing’ was not declared in this scope
Surely, the software is compiling on your system... why not on me?
The version you have is slightly different from the master version, for various practical and historical reasons.
In your case, rename _prepareCustomGuiEvent_noDirectEventProccessing to _prepareCustomGuiEvent_noDirectEventProcessing. Then you should almost be there. We'll try to put an updated version of the source code online within 1-2 days.
Following files were updated:
compilation should be easier now.
BenjaminV
Post by BenjaminV »
Thank you !
The compilation works fine but when I try to launch vrep I have the following error :
QMetaType::registerType: Binary compatibility break -- Size mismatch for type 'QPaintBufferCacheEntry' [1024]. Previously registered size 0, now registering size 16.
But I don't think it's vrep related : I have multiple installation of Qt on my computer (Qt4 Qt5.01 and Qt5.1.1) for compatibility reasons.
So for now I'm going to develop under V-Rep 3.0.4 which compiles and runs fine (I'm actually only working on the path planning plugin)
BenjaminV
Post by BenjaminV »
So I answer myself : the problem was that I had compiled Qscintilla with Qt4.
I recompiled it with Qt5.1.1 and everything is working now!
