I can't run V-REP
Yavhe
Re: I can't run V-REP
Post by Yavhe »
Thanks, I really send you the archive debugLog. I will wait for your answer
Hi again,
we have traced back the crash to a single OpenGL call: glClear()
Since that type of crash is very rare, we have to strongly suppose that you have a problem with your graphic card driver (well, you have an integrated graphic chip, but the problem is the same). Can you try to update to the newest driver version? And also possibly turn off hardware acceleration (or turn it on) to see if that makes a difference.
mputnick
Post by mputnick »
Hello!
I have the same problem again. I can launch V-REP without any errors now, but when I launch C++ program which should open V-REP scenes, error appears: "Error: Could not find or correctly load v_rep.dll".
I have Windows XP SP3 and the last version of V-REP EDU. I tried to install previous versions or launch V-REP from USB-flash like I've done before, but useless.
In the Dependecy Walker picture is that problem with MPR.dll (print screen like in my previous message).
How can I correct this problem? Thank you.
I am not completely sure I understood.. so you can launch V-REP without a problem, is that correct? And when you say you launch a C++ program which should open a V-REP scene, what do you mean? A remote API client that tries to load a scene? A Plugin?
mputnick
Post by mputnick »
Yes, I can launch V-REP without problem if I do it myself.
But when remote API client tries to load a scene, error appears.
Hello again,
I am still confused. So if I understood you correctly, following works:
  • launch V-REP manually (e.g. double-click the vrep.exe)
but following does not work:
  • start a remote API client
  • from within the remote API client, try to load a scene --> the V-REP console displays Error: Could not find or correctly load v_rep.dll
Is that correct? What language are you using for the remote API client?
mputnick
Post by mputnick »
Oh, I'm sorry. Maybe I described not so correct. It was wrong about API functions.
It is works correctly:
- launch V-REP manually (e.g. double-click the vrep.exe)
But I have the program in C++ which tried to launch V-REP so:
file_name = "astiShow.ttt";
commandLine = "D:\\V-REP3\\V-REP_PRO_EDU\\vrep.exe " +file_name;
bool sucsess = CreateProcess(NULL, (LPSTR)commandLine.data(), NULL, NULL, FALSE,
			0,(LPVOID) chNewEnv,NULL,&si_show,&pi_show);
And in this case, when I launch my program, console displays Error: Could not find or correctly load v_rep.dll
ah ok, I see now what you meant!
Before calling the CreateProcess function, try switching to the V-REP directory with SetCurrentDirectoryA, or similar.
mputnick
Post by mputnick »
I tried, but it doesn't help.
And in other computers it works normal.
What else can be cause of this problem?
Tjay
Post by Tjay »
Yavhe wrote: 19 Jun 2014, 15:53 I installed V-REP PRO EDU, but when I tried to launch it, I saw the message: "V-REP stopped working". Then windows closed.
. I tried to reinstall V-REP , but nothing was changed.
What can I do to launch program?
Hi, I am having a similar problem! Please how did you solve it then?
