Is there a way to tempararily disable certain components in the scene? I think having many models and vision sensors may be slowing down my simulation, is there a way to run the simulation without the vision sensors for example? This would be analogous to "commenting out" part of the simulation. I want to be able to quickly remove parts without actually deleting them, so I can get them back quickly as well. Is this possible?
Thanks!
Disabling Components
Re: Disabling Components
you have at least 2 ways of disabling components:
- you can disable for instance all vision sensors: in the vision sensor properties, uncheck Enable all vision sensors.
- when you are dealing with a model, you can disable specific properties of this model. You would do this in the model dialog.
