CoppeliaSim_Edu_V4_5_1_rev4_macOS12 Crashes directly when openning the application
cembilaloglu
Post by cembilaloglu »
When I open the .dmg file and double click to run the application after a couple of seconds the application crashes with the following crash report
Translated Report (Full Report Below)
Process:               coppeliaSim [14896]
Path:                  /Volumes/*/coppeliaSim.app/Contents/MacOS/coppeliaSim
Identifier:            com.coppeliarobotics.coppeliasim
Version:               4.3.0 (4.3.0)
Code Type:             X86-64 (Translated)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2023-04-16 17:09:31.4491 +0200
OS Version:            macOS 13.2 (22D49)
Report Version:        12
Anonymous UUID:        87C54495-C96C-8D43-DB58-F738088BCE01
Sleep/Wake UUID:       0A26AF03-C3C3-4517-916A-8A9044A82E8E
Time Awake Since Boot: 240000 seconds
Time Since Wake:       3840 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes:       0x0000000000000001, 0x0000000000000000
Termination Reason:    Namespace SIGNAL, Code 4 Illegal instruction: 4
Terminating Process:   exc handler [14896]
Thread 0 Crashed::  Dispatch queue: com.apple.main-thread
0   libmujoco.2.3.1.dylib         	       0x13277012f _mj_rosettaError + 31
1   libmujoco.2.3.1.dylib         	       0x13277018c _mj_checkRosetta + 76
2   dyld                          	       0x204d6f618 invocation function for block in dyld4::Loader::findAndRunAllInitializers(dyld4::RuntimeState&) const + 172
3   dyld                          	       0x204daec4d invocation function for block in dyld3::MachOAnalyzer::forEachInitializer(Diagnostics&, dyld3::MachOAnalyzer::VMAddrConverter const&, void (unsigned int) block_pointer, void const*) const + 132
4   dyld                          	       0x204da2ef7 invocation function for block in dyld3::MachOFile::forEachSection(void (dyld3::MachOFile::SectionInfo const&, bool, bool&) block_pointer) const + 557
5   dyld                          	       0x204d550b7 dyld3::MachOFile::forEachLoadCommand(Diagnostics&, void (load_command const*, bool&) block_pointer) const + 245
6   dyld                          	       0x204da20a7 dyld3::MachOFile::forEachSection(void (dyld3::MachOFile::SectionInfo const&, bool, bool&) block_pointer) const + 175
7   dyld                          	       0x204da47ea dyld3::MachOFile::forEachInitializerPointerSection(Diagnostics&, void (unsigned int, unsigned int, bool&) block_pointer) const + 116
8   dyld                          	       0x204dae882 dyld3::MachOAnalyzer::forEachInitializer(Diagnostics&, dyld3::MachOAnalyzer::VMAddrConverter const&, void (unsigned int) block_pointer, void const*) const + 390
9   dyld                          	       0x204d6f4f6 dyld4::Loader::findAndRunAllInitializers(dyld4::RuntimeState&) const + 150
10  dyld                          	       0x204d6f750 dyld4::Loader::runInitializersBottomUp(dyld4::RuntimeState&, dyld3::Array<dyld4::Loader const*>&) const + 178
11  dyld                          	       0x204d6f733 dyld4::Loader::runInitializersBottomUp(dyld4::RuntimeState&, dyld3::Array<dyld4::Loader const*>&) const + 149
12  dyld                          	       0x204d6f82c dyld4::Loader::runInitializersBottomUpPlusUpwardLinks(dyld4::RuntimeState&) const + 164
13  dyld                          	       0x204d8a88f dyld4::APIs::dlopen_from(char const*, int, void*) + 989
14  QtCore                        	       0x10d6d3987 0x10d4ef000 + 1984903
15  QtCore                        	       0x10d6cf258 0x10d4ef000 + 1966680
16  libcoppeliaSim.dylib          	       0x110d1c0ee VVarious::openLibrary(char const*) + 126
17  libcoppeliaSim.dylib          	       0x111175705 CPlugin::load() + 197
18  libcoppeliaSim.dylib          	       0x111176b6b CPluginContainer::addPlugin(char const*, char const*) + 491
19  libcoppeliaSim.dylib          	       0x11111b286 CUiThread::__executeCommandViaUiThread(SUIThreadCommand*, SUIThreadCommand*) + 502
20  libcoppeliaSim.dylib          	       0x11111b07a CUiThread::executeCommandViaUiThread(SUIThreadCommand*, SUIThreadCommand*) + 42
21  libcoppeliaSim.dylib          	       0x110f723fc simLoadModule_internal(char const*, char const*) + 588
22  libcoppeliaSim.dylib          	       0x110f71350 simulatorInit() + 3088
23  libcoppeliaSim.dylib          	       0x11113fd4f App::run(void (*)(), void (*)(), void (*)(), bool) + 143
24  libcoppeliaSim.dylib          	       0x110f74295 simRunSimulator_internal(char const*, int, void (*)(), void (*)(), void (*)(), int, char const*, bool) + 1221
25  libcoppeliaSim.dylib          	       0x110f65c3e simRunSimulatorEx + 14
26  coppeliaSim                   	       0x104976208 0x104972000 + 16904
27  coppeliaSim                   	       0x1049766ed 0x104972000 + 18157
28  dyld                          	       0x204d59310 start + 2432
Thread 1:: com.apple.rosetta.exceptionserver
0   runtime                       	    0x7ff7ffd0b614 0x7ff7ffd07000 + 17940
1   runtime                       	    0x7ff7ffd17530 0x7ff7ffd07000 + 66864
2   runtime                       	    0x7ff7ffd18f30 0x7ff7ffd07000 + 73520
Thread 2:
0   runtime                       	    0x7ff7ffd2987c 0x7ff7ffd07000 + 141436
Thread 3:
Thread 4:
Thread 5:
Thread 6:: Thread (pooled)
0   ???                           	    0x7ff89394e9a8 ???
1   libsystem_kernel.dylib        	    0x7ff8045ad11a __psynch_cvwait + 10
2   libsystem_pthread.dylib       	    0x7ff8045e97e1 _pthread_cond_wait + 1243
3   QtCore                        	       0x10d519fec 0x10d4ef000 + 176108
4   QtCore                        	       0x10d519cee 0x10d4ef000 + 175342
5   QtCore                        	       0x10d519c44 QWaitCondition::wait(QMutex*, QDeadlineTimer) + 84
6   QtCore                        	       0x10d5164de 0x10d4ef000 + 160990
7   QtCore                        	       0x10d511f60 0x10d4ef000 + 143200
8   libsystem_pthread.dylib       	    0x7ff8045e9259 _pthread_start + 125
9   libsystem_pthread.dylib       	    0x7ff8045e4c7b thread_start + 15
Thread 7::  Dispatch queue: com.apple.root.user-interactive-qos
1   libsystem_kernel.dylib        	    0x7ff8045aa556 semaphore_timedwait_trap + 10
2   libdispatch.dylib             	    0x7ff804469f75 _dispatch_sema4_timedwait + 72
3   libdispatch.dylib             	    0x7ff80446a3af _dispatch_semaphore_wait_slow + 58
4   AppKit                        	    0x7ff8080eb6e3 __22-[NSCGSLocalFence set]_block_invoke_2 + 147
5   QuartzCore                    	    0x7ff80c6b5f60 CA::Transaction::run_commit_handlers(CATransactionPhase) + 98
6   QuartzCore                    	    0x7ff80c84d7b5 CA::Context::commit_transaction(CA::Transaction*, double, double*) + 887
7   QuartzCore                    	    0x7ff80c6b4b35 CA::Transaction::commit() + 725
8   AppKit                        	    0x7ff807799318 NSPerformVisuallyAtomicChange + 154
9   AppKit                        	    0x7ff80799d434 -[_NSWindowTransformAnimation _stopAnimation:withDisplayLink:] + 111
10  AppKit                        	    0x7ff8079086e7 -[NSScreenDisplayLink _fire] + 156
11  AppKit                        	    0x7ff80817d7cc ___NSRunLoopTimerCreateWithHandler_block_invoke + 34
12  CoreFoundation                	    0x7ff8046dcb2d __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
13  CoreFoundation                	    0x7ff8046dc697 __CFRunLoopDoTimer + 820
14  CoreFoundation                	    0x7ff8046dc2b1 __CFRunLoopDoTimers + 285
15  CoreFoundation                	    0x7ff8046c2d57 __CFRunLoopRun + 2142
16  CoreFoundation                	    0x7ff8046c1e7f CFRunLoopRunSpecific + 560
17  Foundation                    	    0x7ff80545902a -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 216
18  AppKit                        	    0x7ff807b6818a -[NSAnimation _runBlocking] + 446
19  AppKit                        	    0x7ff807b684ed __30-[NSAnimation _runInNewThread]_block_invoke + 97
20  libdispatch.dylib             	    0x7ff8044687fb _dispatch_call_block_and_release + 12
21  libdispatch.dylib             	    0x7ff804469a44 _dispatch_client_callout + 8
22  libdispatch.dylib             	    0x7ff8044797f6 _dispatch_root_queue_drain + 683
23  libdispatch.dylib             	    0x7ff804479e4d _dispatch_worker_thread2 + 160
24  libsystem_pthread.dylib       	    0x7ff8045e5c9d _pthread_wqthread + 256
25  libsystem_pthread.dylib       	    0x7ff8045e4c67 start_wqthread + 15
Thread 8:
Thread 9:
Thread 10:: com.apple.NSEventThread
1   libsystem_kernel.dylib        	    0x7ff8045aa5c2 mach_msg2_trap + 10
2   libsystem_kernel.dylib        	    0x7ff8045b8604 mach_msg2_internal + 82
3   libsystem_kernel.dylib        	    0x7ff8045b1635 mach_msg_overwrite + 723
4   libsystem_kernel.dylib        	    0x7ff8045aa8a8 mach_msg + 19
5   CoreFoundation                	    0x7ff8046c400b __CFRunLoopServiceMachPort + 145
6   CoreFoundation                	    0x7ff8046c2a64 __CFRunLoopRun + 1387
7   CoreFoundation                	    0x7ff8046c1e7f CFRunLoopRunSpecific + 560
8   AppKit                        	    0x7ff8078ae129 _NSEventThread + 132
9   libsystem_pthread.dylib       	    0x7ff8045e9259 _pthread_start + 125
10  libsystem_pthread.dylib       	    0x7ff8045e4c7b thread_start + 15
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000042  rbx: 0x000000030d7b90d8  rcx: 0x74f450d361440074  rdx: 0x0000000000000000
  rdi: 0x00007ff847c62538  rsi: 0x00000000000120a8  rbp: 0x000000030d7b90a0  rsp: 0x000000030d7b90a0
   r8: 0x00007ff847c62558   r9: 0x0000000000000000  r10: 0x00000000ffffff00  r11: 0x00007ff847c62550
  r12: 0x00000001329736f0  r13: 0x0000000132753650  r14: 0x0000000132770140  r15: 0x000000030d7b95c8
  rip: <unavailable>       rfl: 0x0000000000000202
 tmp0: 0x000000013277012f tmp1: 0x0000000000000214 tmp2: 0x00000001329cabb0
Binary Images:
       0x132753000 -        0x132972fff libmujoco.2.3.1.dylib (*) <f65221ff-3fbc-3d70-b249-a128619e8f93> /Volumes/*/coppeliaSim.app/Contents/Frameworks/libmujoco.2.3.1.dylib
       0x204d53000 -        0x204deafff dyld (*) <270c4224-a38f-3a22-9ba9-95968f487738> /usr/lib/dyld
       0x10d4ef000 -        0x10d996fff org.qt-project.QtCore (5.15) <b27ea0b4-e473-3f59-b191-455a6c61a3b4> /Volumes/*/coppeliaSim.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
       0x110b88000 -        0x1113a7fff libcoppeliaSim.dylib (*) <8b99b260-acef-34a1-aab2-274f98cbc112> /Volumes/*/coppeliaSim.app/Contents/MacOS/libcoppeliaSim.dylib
       0x104972000 -        0x104981fff com.coppeliarobotics.coppeliasim (4.3.0) <d14d3d80-7bca-37d8-a67b-58b448fae6a8> /Volumes/*/coppeliaSim.app/Contents/MacOS/coppeliaSim
    0x7ff7ffd07000 -     0x7ff7ffd36fff runtime (*) <f066db2c-ed38-3f37-8d21-81d15fa908fe> /usr/libexec/rosetta/runtime
               0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
    0x7ff8045a9000 -     0x7ff8045e2ff7 libsystem_kernel.dylib (*) <ca136b67-0559-3f19-8b7e-9b80438090b6> /usr/lib/system/libsystem_kernel.dylib
    0x7ff8045e3000 -     0x7ff8045eeff7 libsystem_pthread.dylib (*) <3bd433d4-15bd-3add-a612-95e4d3b20719> /usr/lib/system/libsystem_pthread.dylib
    0x7ff804467000 -     0x7ff8044adff3 libdispatch.dylib (*) <d59ee79a-169a-3799-8ea1-c8ad56bb11c9> /usr/lib/system/libdispatch.dylib
    0x7ff80770f000 -     0x7ff808717ff2 com.apple.AppKit (6.9) <480a5693-f3e3-3b50-a1f3-169d12a12a0e> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7ff80c6b2000 -     0x7ff80ca04ff3 com.apple.QuartzCore (1.11) <c24311d4-71c0-372c-869c-b3c4961a4174> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7ff804645000 -     0x7ff804adcfff com.apple.CoreFoundation (6.9) <be859dcd-e5ee-3aab-97e4-13231468695f> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7ff8053fa000 -     0x7ff805e0bff6 com.apple.Foundation (6.9) <a58576df-7109-3a13-a338-617f135ce8a8> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=726.9M resident=0K(0%) swapped_out_or_unallocated=726.9M(100%)
Writable regions: Total=2.9G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.9G(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               256K        2
Activity Tracing                   256K        1
CG backing stores                 3520K        4
CG image                          2052K        1
ColorSync                          224K       25
CoreAnimation                        8K        2
CoreGraphics                        20K        3
CoreUI image data                  304K        1
Foundation                          16K        1
Kernel Alloc Once                    8K        1
MALLOC                           289.7M       55
MALLOC guard page                  192K        9
MALLOC_MEDIUM (reserved)         840.0M        7         reserved VM address space (unallocated)
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
Rosetta Arena                     4096K        2
Rosetta Generic                   1240K      307
Rosetta IndirectBranch            1024K        1
Rosetta JIT                      128.0M        1
Rosetta Return Stack               200K       20
Rosetta Thread Context             200K       20
STACK GUARD                         24K        6
Stack                             12.6M       10
Stack Guard                       56.0M        4
VM_ALLOCATE                       8188K      163
VM_ALLOCATE (reserved)             1.1G       82         reserved VM address space (unallocated)
__CTF                               756        1
__DATA                            45.9M      500
__DATA_CONST                      20.6M      336
__DATA_DIRTY                       754K      115
__FONT_DATA                        2352        1
__GLSLBUILTINS                    5174K        1
__LINKEDIT                       190.4M      164
__OBJC_RO                         65.4M        1
__OBJC_RW                         1987K        2
__TEXT                           536.5M      526
dyld private memory                256K        1
mapped file                        4.4G     1720
shared memory                     1320K       16
unshared pmap                     8976K        5
TOTAL                              8.1G     4118
TOTAL, minus reserved VM space     5.8G     4118
Full Report
{"app_name":"coppeliaSim","timestamp":"2023-04-16 17:09:31.00 +0200","app_version":"4.3.0","slice_uuid":"d14d3d80-7bca-37d8-a67b-58b448fae6a8","build_version":"4.3.0","platform":1,"bundleID":"com.coppeliarobotics.coppeliasim","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 13.2 (22D49)","roots_installed":0,"name":"coppeliaSim","incident_id":"B0B1A49C-A089-4318-8070-3D9D8CF69833"}
  "uptime" : 240000,
  "procRole" : "Foreground",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "MacBookPro18,3",
  "coalitionID" : 38641,
  "osVersion" : {
    "train" : "macOS 13.2",
    "build" : "22D49",
    "releaseType" : "User"
  "captureTime" : "2023-04-16 17:09:31.4491 +0200",
  "incident" : "B0B1A49C-A089-4318-8070-3D9D8CF69833",
  "pid" : 14896,
  "translated" : true,
  "cpuType" : "X86-64",
  "roots_installed" : 0,
  "bug_type" : "309",
  "procLaunch" : "2023-04-16 17:09:27.9838 +0200",
  "procStartAbsTime" : 5988737307941,
  "procExitAbsTime" : 5988820175844,
  "procName" : "coppeliaSim",
  "procPath" : "\/Volumes\/*\/coppeliaSim.app\/Contents\/MacOS\/coppeliaSim",
  "bundleInfo" : {"CFBundleShortVersionString":"4.3.0","CFBundleVersion":"4.3.0","CFBundleIdentifier":"com.coppeliarobotics.coppeliasim"},
  "storeInfo" : {"deviceIdentifierForVendor":"CBB18C20-186E-5CF0-B353-95BC67883579","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "com.coppeliarobotics.coppeliasim",
  "crashReporterKey" : "87C54495-C96C-8D43-DB58-F738088BCE01",
  "throttleTimeout" : 2147483647,
  "wakeTime" : 3840,
  "sleepWakeUUID" : "0A26AF03-C3C3-4517-916A-8A9044A82E8E",
  "sip" : "enabled",
  "exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_BAD_INSTRUCTION","signal":"SIGILL"},
  "termination" : {"flags":0,"code":4,"namespace":"SIGNAL","indicator":"Illegal instruction: 4","byProc":"exc handler","byPid":14896},
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 0,
  "threads" : [{"triggered":true,"id":4899337,"threadState":{"flavor":"x86_THREAD_STATE","rbp":{"value":13111103648},"r12":{"value":5143738096},"rosetta":{"tmp2":{"value":5144095664},"tmp1":{"value":532},"tmp0":{"value":5141627183}},"rbx":{"value":13111103704},"r8":{"value":140704332784984,"symbolLocation":456,"symbol":"__sFX"},"r15":{"value":13111104968},"r10":{"value":4294967040},"rdx":{"value":0},"rdi":{"value":140704332784952,"symbolLocation":424,"symbol":"__sFX"},"r9":{"value":0},"r13":{"value":5141509712},"rflags":{"value":514},"rax":{"value":66},"rsp":{"value":13111103648},"r11":{"value":140704332784976,"symbolLocation":448,"symbol":"__sFX"},"rcx":{"value":8427449671517208692},"r14":{"value":5141627200,"symbolLocation":0,"symbol":"_mj_checkRosetta"},"rsi":{"value":73896}},"queue":"com.apple.main-thread","frames":[{"imageOffset":119087,"symbol":"_mj_rosettaError","symbolLocation":31,"imageIndex":0},{"imageOffset":119180,"symbol":"_mj_checkRosetta","symbolLocation":76,"imageIndex":0},{"imageOffset":116248,"symbol":"invocation function for block in dyld4::Loader::findAndRunAllInitializers(dyld4::RuntimeState&) const","symbolLocation":172,"imageIndex":1},{"imageOffset":375885,"symbol":"invocation function for block in dyld3::MachOAnalyzer::forEachInitializer(Diagnostics&, dyld3::MachOAnalyzer::VMAddrConverter const&, void (unsigned int) block_pointer, void const*) const","symbolLocation":132,"imageIndex":1},{"imageOffset":327415,"symbol":"invocation function for block in dyld3::MachOFile::forEachSection(void (dyld3::MachOFile::SectionInfo const&, bool, bool&) block_pointer) const","symbolLocation":557,"imageIndex":1},{"imageOffset":8375,"symbol":"dyld3::MachOFile::forEachLoadCommand(Diagnostics&, void (load_command const*, bool&) block_pointer) const","symbolLocation":245,"imageIndex":1},{"imageOffset":323751,"symbol":"dyld3::MachOFile::forEachSection(void (dyld3::MachOFile::SectionInfo const&, bool, bool&) block_pointer) const","symbolLocation":175,"imageIndex":1},{"imageOffset":333802,"symbol":"dyld3::MachOFile::forEachInitializerPointerSection(Diagnostics&, void (unsigned int, unsigned int, bool&) block_pointer) const","symbolLocation":116,"imageIndex":1},{"imageOffset":374914,"symbol":"dyld3::MachOAnalyzer::forEachInitializer(Diagnostics&, dyld3::MachOAnalyzer::VMAddrConverter const&, void (unsigned int) block_pointer, void const*) const","symbolLocation":390,"imageIndex":1},{"imageOffset":115958,"symbol":"dyld4::Loader::findAndRunAllInitializers(dyld4::RuntimeState&) const","symbolLocation":150,"imageIndex":1},{"imageOffset":116560,"symbol":"dyld4::Loader::runInitializersBottomUp(dyld4::RuntimeState&, dyld3::Array<dyld4::Loader const*>&) const","symbolLocation":178,"imageIndex":1},{"imageOffset":116531,"symbol":"dyld4::Loader::runInitializersBottomUp(dyld4::RuntimeState&, dyld3::Array<dyld4::Loader const*>&) const","symbolLocation":149,"imageIndex":1},{"imageOffset":116780,"symbol":"dyld4::Loader::runInitializersBottomUpPlusUpwardLinks(dyld4::RuntimeState&) const","symbolLocation":164,"imageIndex":1},{"imageOffset":227471,"symbol":"dyld4::APIs::dlopen_from(char const*, int, void*)","symbolLocation":989,"imageIndex":1},{"imageOffset":1984903,"imageIndex":2},{"imageOffset":1966680,"imageIndex":2},{"imageOffset":1655022,"symbol":"VVarious::openLibrary(char const*)","symbolLocation":126,"imageIndex":3},{"imageOffset":6215429,"symbol":"CPlugin::load()","symbolLocation":197,"imageIndex":3},{"imageOffset":6220651,"symbol":"CPluginContainer::addPlugin(char const*, char const*)","symbolLocation":491,"imageIndex":3},{"imageOffset":5845638,"symbol":"CUiThread::__executeCommandViaUiThread(SUIThreadCommand*, SUIThreadCommand*)","symbolLocation":502,"imageIndex":3},{"imageOffset":5845114,"symbol":"CUiThread::executeCommandViaUiThread(SUIThreadCommand*, SUIThreadCommand*)","symbolLocation":42,"imageIndex":3},{"imageOffset":4105212,"symbol":"simLoadModule_internal(char const*, char const*)","symbolLocation":588,"imageIndex":3},{"imageOffset":4100944,"symbol":"simulatorInit()","symbolLocation":3088,"imageIndex":3},{"imageOffset":5995855,"symbol":"App::run(void (*)(), void (*)(), void (*)(), bool)","symbolLocation":143,"imageIndex":3},{"imageOffset":4113045,"symbol":"simRunSimulator_internal(char const*, int, void (*)(), void (*)(), void (*)(), int, char const*, bool)","symbolLocation":1221,"imageIndex":3},{"imageOffset":4054078,"symbol":"simRunSimulatorEx","symbolLocation":14,"imageIndex":3},{"imageOffset":16904,"imageIndex":4},{"imageOffset":18157,"imageIndex":4},{"imageOffset":25360,"symbol":"start","symbolLocation":2432,"imageIndex":1}]},{"id":4899348,"name":"com.apple.rosetta.exceptionserver","frames":[{"imageOffset":17940,"imageIndex":5},{"imageOffset":66864,"imageIndex":5},{"imageOffset":73520,"imageIndex":5}]},{"id":4899358,"frames":[{"imageOffset":141436,"imageIndex":5}]},{"id":4899359,"frames":[{"imageOffset":141436,"imageIndex":5}]},{"id":4899362,"frames":[{"imageOffset":141436,"imageIndex":5}]},{"id":4899363,"frames":[{"imageOffset":141436,"imageIndex":5}]},{"id":4899364,"name":"Thread (pooled)","frames":[{"imageOffset":140705604626856,"imageIndex":6},{"imageOffset":16666,"symbol":"__psynch_cvwait","symbolLocation":10,"imageIndex":7},{"imageOffset":26593,"symbol":"_pthread_cond_wait","symbolLocation":1243,"imageIndex":8},{"imageOffset":176108,"imageIndex":2},{"imageOffset":175342,"imageIndex":2},{"imageOffset":175172,"symbol":"QWaitCondition::wait(QMutex*, QDeadlineTimer)","symbolLocation":84,"imageIndex":2},{"imageOffset":160990,"imageIndex":2},{"imageOffset":143200,"imageIndex":2},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]},{"id":4899365,"queue":"com.apple.root.user-interactive-qos","frames":[{"imageOffset":140705604626856,"imageIndex":6},{"imageOffset":5462,"symbol":"semaphore_timedwait_trap","symbolLocation":10,"imageIndex":7},{"imageOffset":12149,"symbol":"_dispatch_sema4_timedwait","symbolLocation":72,"imageIndex":9},{"imageOffset":13231,"symbol":"_dispatch_semaphore_wait_slow","symbolLocation":58,"imageIndex":9},{"imageOffset":10340067,"symbol":"__22-[NSCGSLocalFence set]_block_invoke_2","symbolLocation":147,"imageIndex":10},{"imageOffset":16224,"symbol":"CA::Transaction::run_commit_handlers(CATransactionPhase)","symbolLocation":98,"imageIndex":11},{"imageOffset":1685429,"symbol":"CA::Context::commit_transaction(CA::Transaction*, double, double*)","symbolLocation":887,"imageIndex":11},{"imageOffset":11061,"symbol":"CA::Transaction::commit()","symbolLocation":725,"imageIndex":11},{"imageOffset":566040,"symbol":"NSPerformVisuallyAtomicChange","symbolLocation":154,"imageIndex":10},{"imageOffset":2679860,"symbol":"-[_NSWindowTransformAnimation _stopAnimation:withDisplayLink:]","symbolLocation":111,"imageIndex":10},{"imageOffset":2070247,"symbol":"-[NSScreenDisplayLink _fire]","symbolLocation":156,"imageIndex":10},{"imageOffset":10938316,"symbol":"___NSRunLoopTimerCreateWithHandler_block_invoke","symbolLocation":34,"imageIndex":10},{"imageOffset":621357,"symbol":"__CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__","symbolLocation":20,"imageIndex":12},{"imageOffset":620183,"symbol":"__CFRunLoopDoTimer","symbolLocation":820,"imageIndex":12},{"imageOffset":619185,"symbol":"__CFRunLoopDoTimers","symbolLocation":285,"imageIndex":12},{"imageOffset":515415,"symbol":"__CFRunLoopRun","symbolLocation":2142,"imageIndex":12},{"imageOffset":511615,"symbol":"CFRunLoopRunSpecific","symbolLocation":560,"imageIndex":12},{"imageOffset":389162,"symbol":"-[NSRunLoop(NSRunLoop) runMode:beforeDate:]","symbolLocation":216,"imageIndex":13},{"imageOffset":4559242,"symbol":"-[NSAnimation _runBlocking]","symbolLocation":446,"imageIndex":10},{"imageOffset":4560109,"symbol":"__30-[NSAnimation _runInNewThread]_block_invoke","symbolLocation":97,"imageIndex":10},{"imageOffset":6139,"symbol":"_dispatch_call_block_and_release","symbolLocation":12,"imageIndex":9},{"imageOffset":10820,"symbol":"_dispatch_client_callout","symbolLocation":8,"imageIndex":9},{"imageOffset":75766,"symbol":"_dispatch_root_queue_drain","symbolLocation":683,"imageIndex":9},{"imageOffset":77389,"symbol":"_dispatch_worker_thread2","symbolLocation":160,"imageIndex":9},{"imageOffset":11421,"symbol":"_pthread_wqthread","symbolLocation":256,"imageIndex":8},{"imageOffset":7271,"symbol":"start_wqthread","symbolLocation":15,"imageIndex":8}]},{"id":4899366,"frames":[{"imageOffset":141436,"imageIndex":5}]},{"id":4899367,"frames":[{"imageOffset":141436,"imageIndex":5}]},{"id":4899369,"name":"com.apple.NSEventThread","frames":[{"imageOffset":140705604626856,"imageIndex":6},{"imageOffset":5570,"symbol":"mach_msg2_trap","symbolLocation":10,"imageIndex":7},{"imageOffset":62980,"symbol":"mach_msg2_internal","symbolLocation":82,"imageIndex":7},{"imageOffset":34357,"symbol":"mach_msg_overwrite","symbolLocation":723,"imageIndex":7},{"imageOffset":6312,"symbol":"mach_msg","symbolLocation":19,"imageIndex":7},{"imageOffset":520203,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":145,"imageIndex":12},{"imageOffset":514660,"symbol":"__CFRunLoopRun","symbolLocation":1387,"imageIndex":12},{"imageOffset":511615,"symbol":"CFRunLoopRunSpecific","symbolLocation":560,"imageIndex":12},{"imageOffset":1700137,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":10},{"imageOffset":25177,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":8},{"imageOffset":7291,"symbol":"thread_start","symbolLocation":15,"imageIndex":8}]}],
  "usedImages" : [
    "source" : "P",
    "arch" : "x86_64",
    "base" : 5141508096,
    "size" : 2228224,
    "uuid" : "f65221ff-3fbc-3d70-b249-a128619e8f93",
    "path" : "\/Volumes\/*\/coppeliaSim.app\/Contents\/Frameworks\/libmujoco.2.3.1.dylib",
    "name" : "libmujoco.2.3.1.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 8671014912,
    "size" : 622592,
    "uuid" : "270c4224-a38f-3a22-9ba9-95968f487738",
    "path" : "\/usr\/lib\/dyld",
    "name" : "dyld"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4518244352,
    "CFBundleShortVersionString" : "5.15",
    "CFBundleIdentifier" : "org.qt-project.QtCore",
    "size" : 4882432,
    "uuid" : "b27ea0b4-e473-3f59-b191-455a6c61a3b4",
    "path" : "\/Volumes\/*\/coppeliaSim.app\/Contents\/Frameworks\/QtCore.framework\/Versions\/5\/QtCore",
    "name" : "QtCore",
    "CFBundleVersion" : "5.15.8"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4575494144,
    "size" : 8519680,
    "uuid" : "8b99b260-acef-34a1-aab2-274f98cbc112",
    "path" : "\/Volumes\/*\/coppeliaSim.app\/Contents\/MacOS\/libcoppeliaSim.dylib",
    "name" : "libcoppeliaSim.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4371980288,
    "CFBundleShortVersionString" : "4.3.0",
    "CFBundleIdentifier" : "com.coppeliarobotics.coppeliasim",
    "size" : 65536,
    "uuid" : "d14d3d80-7bca-37d8-a67b-58b448fae6a8",
    "path" : "\/Volumes\/*\/coppeliaSim.app\/Contents\/MacOS\/coppeliaSim",
    "name" : "coppeliaSim",
    "CFBundleVersion" : "4.3.0"
    "source" : "P",
    "arch" : "arm64",
    "base" : 140703125499904,
    "size" : 196608,
    "uuid" : "f066db2c-ed38-3f37-8d21-81d15fa908fe",
    "path" : "\/usr\/libexec\/rosetta\/runtime",
    "name" : "runtime"
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703201660928,
    "size" : 237560,
    "uuid" : "ca136b67-0559-3f19-8b7e-9b80438090b6",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703201898496,
    "size" : 49144,
    "uuid" : "3bd433d4-15bd-3add-a612-95e4d3b20719",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703200342016,
    "size" : 290804,
    "uuid" : "d59ee79a-169a-3799-8ea1-c8ad56bb11c9",
    "path" : "\/usr\/lib\/system\/libdispatch.dylib",
    "name" : "libdispatch.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703253458944,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 16814067,
    "uuid" : "480a5693-f3e3-3b50-a1f3-169d12a12a0e",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2299.40.116"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703336964096,
    "CFBundleShortVersionString" : "1.11",
    "CFBundleIdentifier" : "com.apple.QuartzCore",
    "size" : 3485684,
    "uuid" : "c24311d4-71c0-372c-869c-b3c4961a4174",
    "path" : "\/System\/Library\/Frameworks\/QuartzCore.framework\/Versions\/A\/QuartzCore",
    "name" : "QuartzCore",
    "CFBundleVersion" : "1042.30"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703202299904,
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 4816896,
    "uuid" : "be859dcd-e5ee-3aab-97e4-13231468695f",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "1953.300"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703216672768,
    "CFBundleIdentifier" : "com.apple.Foundation",
    "size" : 10559479,
    "uuid" : "a58576df-7109-3a13-a338-617f135ce8a8",
    "path" : "\/System\/Library\/Frameworks\/Foundation.framework\/Versions\/C\/Foundation",
    "name" : "Foundation",
  "sharedCache" : {
  "base" : 140703197937664,
  "size" : 21474836480,
  "uuid" : "efc722b9-b3df-3d27-9a7b-c4acaf125abb"
  "vmSummary" : "ReadOnly portion of Libraries: Total=726.9M resident=0K(0%) swapped_out_or_unallocated=726.9M(100%)\nWritable regions: Total=2.9G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.9G(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               256K        2 \nActivity Tracing                   256K        1 \nCG backing stores                 3520K        4 \nCG image                          2052K        1 \nColorSync                          224K       25 \nCoreAnimation                        8K        2 \nCoreGraphics                        20K        3 \nCoreUI image data                  304K        1 \nFoundation                          16K        1 \nKernel Alloc Once                    8K        1 \nMALLOC                           289.7M       55 \nMALLOC guard page                  192K        9 \nMALLOC_MEDIUM (reserved)         840.0M        7         reserved VM address space (unallocated)\nMALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)\nRosetta Arena                     4096K        2 \nRosetta Generic                   1240K      307 \nRosetta IndirectBranch            1024K        1 \nRosetta JIT                      128.0M        1 \nRosetta Return Stack               200K       20 \nRosetta Thread Context             200K       20 \nSTACK GUARD                         24K        6 \nStack                             12.6M       10 \nStack Guard                       56.0M        4 \nVM_ALLOCATE                       8188K      163 \nVM_ALLOCATE (reserved)             1.1G       82         reserved VM address space (unallocated)\n__CTF                               756        1 \n__DATA                            45.9M      500 \n__DATA_CONST                      20.6M      336 \n__DATA_DIRTY                       754K      115 \n__FONT_DATA                        2352        1 \n__GLSLBUILTINS                    5174K        1 \n__LINKEDIT                       190.4M      164 \n__OBJC_RO                         65.4M        1 \n__OBJC_RW                         1987K        2 \n__TEXT                           536.5M      526 \ndyld private memory                256K        1 \nmapped file                        4.4G     1720 \nshared memory                     1320K       16 \nunshared pmap                     8976K        5 \n===========                     =======  ======= \nTOTAL                              8.1G     4118 \nTOTAL, minus reserved VM space     5.8G     4118 \n",
  "legacyInfo" : {
  "threadTriggered" : {
    "queue" : "com.apple.main-thread"
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "63582c5f8a53461413999550",
      "factorPackIds" : {
      "deploymentId" : 240000002
      "rolloutId" : "6347054113acce15305b7b82",
      "factorPackIds" : {
        "SIRI_MEMORY_SYNC_CONFIG" : "634705e78e8be655c1316a6e"
      "deploymentId" : 240000005
  "experiments" : [
      "treatmentId" : "c28e4ee6-1b08-4f90-8e05-2809e78310a3",
      "experimentId" : "6317d2003d24842ff850182a",
      "deploymentId" : 400000012
Model: MacBookPro18,3, BootROM 8419.80.7, proc 10:8:2 processors, 32 GB, SMC
Graphics: Apple M1 Pro, Apple M1 Pro, Built-In
Display: Color LCD, 3024 x 1964 Retina, Main, MirrorOff, Online
Memory Module: LPDDR5, Hynix
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x4387), wl0: Nov 30 2022 02:17:16 version 20.10.965.13.8.7.131 FWID 01-1251c18d
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
Thunderbolt Bus: MacBook Pro, Apple Inc.
Re: CoppeliaSim_Edu_V4_5_1_rev4_macOS12 Crashes directly when openning the application
cembilaloglu wrote: 16 Apr 2023, 16:12 Exception Type: EXC_BAD_INSTRUCTION (SIGILL)
Thanks for the report.
The MuJoCo plugin is known to not work with Apple Silicon Macs in Rosetta mode.
Until a native Apple Silicon build is released, remove the MuJoCo plugin (in Finder, right click on the app file -> Show Package Contents, navigate to Contents / MacOS and then remove the libsimExtMujoco.dylib file) to fix this issue.
we have a first version of CoppeliaSim for Apple Silicon macs that you can download here.
pcoates33
Post by pcoates33 »
I just wanted to say a big thank you for making a mac silicon download available.
And also to suggest adding the mac silicon as an option on your download page as currently it only offers the intel option.
I tried to install CoppeliaSim about 3 weeks ago, but had no joy. However, this latest download seems to work fine on my M2 mac mini.
