IK solver failed and robot arm model was incorrectly displayed
lin
Post by lin »
hello!
When the inverse motion solution module was used, the robot arm model was incorrectly displayed and IK model could not be used.
this is the photo and subscript codes.
    local simBase=sim.getObject('.')
    local simTip=sim.getObject('./tip')
    local simTarget=sim.getObject('./testPose1')
    -- create an IK environment:
    ikEnv=simIK.createEnvironment()
    -- create an IK group:
    ikGroup_undamped=simIK.createGroup(ikEnv)
    -- set its resolution method to undamped:
    simIK.setGroupCalculation(ikEnv,ikGroup_undamped,simIK.method_pseudo_inverse,0,6)
    -- create an IK element based on the scene content:
    simIK.addElementFromScene(ikEnv,ikGroup_undamped,simBase,simTip,simTarget,simIK.constraint_pose)
    -- create another IK group:
    ikGroup_damped=simIK.createGroup(ikEnv)
    -- set its resolution method to damped:
    simIK.setGroupCalculation(ikEnv,ikGroup_damped,simIK.method_damped_least_squares,1,99)
    simIK.addElementFromScene(ikEnv,ikGroup_damped,simBase,simTip,simTarget,simIK.constraint_pose)
function sysCall_actuation()
    if simIK.handleGroup(ikEnv,ikGroup_damped,{syncWorlds=true})~=simIK.result_success then
        -- the position/orientation could not be reached.
        -- try to solve with the damped method:
        -- We display a IK failure report message:
        sim.addLog(sim.verbosity_scriptwarnings,"IK solver failed.")
function sysCall_cleanup()
    -- erase the IK environment:
    simIK.eraseEnvironment(ikEnv)
cheers!
Re: IK solver failed and robot arm model was incorrectly displayed
please post the scene.
lin
Post by lin »
Hello!
This is the scene photo.
The summary of the problem is that the robot arms fell apart during simulation and coppeliasim dispalys "IK solver failed" while running the IK model.
But when I set the model to "Model is not dynamic", the robot arms won't fall apart anymore. I don't know if it is the right method.
Thanks,
cheers!
The right method depends of if you need dynamics or not.
Posting a picture is often not enough. Please post a link to e.g. a file in your dropbox, etc.
