ZeroMQ Remote API with getContactInfo() C++ Bug
CroCr
Post by CroCr »
Take a look at this c++ code,
#include <iostream>
#include <vector>
#include <tuple>
#include <chrono>
#include <thread>
#include "RemoteAPIClient.h"
using namespace std;
int main(int, char**)
    RemoteAPIClient client;
    auto sim = client.getObject().sim();
    client.setStepping(true);
    sim.startSimulation();
    std::this_thread::sleep_for(std::chrono::milliseconds(1000));
    auto CapsuleHandle = sim.getObject("./Capsule");
    auto data = sim.getContactInfo(0,CapsuleHandle,sim.handleflag_extended);
    while( sim.getSimulationState() != 0 )
        client.step();
    return 0;
I get this error
terminate called after throwing an instance of 'jsoncons::json_runtime_error<std::out_of_range, void>'
  what():  Invalid array subscript
Aborted (core dumped)
The Capsule handle returns valid input (i.e. 60).
CoppeliaSim Edu, Version 4.5.1 (rev. 4) 64bit (serialization version 24). Ubuntu 18.04 LTS.
Re: ZeroMQ Remote API with getContactInfo() C++ Bug
you are correct. A workaround is to add following to line 2 in lua/sim.lua:
_S.getContactInfo = sim.getContactInfo
function sim.getContactInfo(...)
    local a, b, c, d = _S.getContactInfo(...)
    if a == nil then
        a = {} b = {} c = {} d = {}
    return a, b, c, d
CroCr
Post by CroCr »
coppelia wrote: 30 Oct 2023, 07:57 Hello,
    if a == nil then
    return a, b, c, d
I've placed it and i get this error
terminate called after throwing an instance of 'jsoncons::conv_error'
  what():  Cannot convert to vector
I cannot reproduce your error (at least on CoppeliaSim V4.6). At what stage exactly is the error produced?
CroCr
Post by CroCr »
coppelia wrote: 02 Nov 2023, 08:58 I cannot reproduce your error (at least on CoppeliaSim V4.6). At what stage exactly is the error produced?
I didn't understand your question. I'm running the exact C++ example above. You've advised to add some new lines to sim.lua. Adding the suggested lines yields another errors.
