Java ZMQ Remote API not able to build
Posted: 14 Nov 2023, 10:23
by Andres
Hi, I am not able to use the Java client for ZMQ with Coppelia.
Every time I try to build the Maven, I get this error:
Python was not found; run without arguments to install from the Microsoft Store, or disable this shortcut from Settings > Manage App Execution Aliases.
I have this:
CoppeliaSim 4.6.0 rev2
Windows 11
Java 20.0.2
Apache Maven 3.9.5
Python 3.11.5
I am running the code that comes by default in: ...\CoppeliaRobotics\CoppeliaSimEdu\programming\zmqRemoteApi\clients\java
I have not made any changes to your code but still the build fails.
Thanks for your help.
Re: Java ZMQ Remote API not able to build
Posted: 14 Nov 2023, 15:47
what does it print when you type:
py --version
python --version
python3 --version
Posted: 15 Nov 2023, 11:44
by Andres
C:\Users\rahm->py --version
Python 3.11.5
C:\Users\rahm->python --version
Python 3.11.5
C:\Users\rahm->python3 --version
Posted: 15 Nov 2023, 11:59
by Andres
It is weird that the python and py commands work, but the python3 command does not. According to this link, it seems that Python3 is not a command in Windows 11.
https://stackoverflow.com/questions/483 ... python-ver
Is there any way to fix that?
