QT UI hslider initial value can't exceed 100
javqui
Post by javqui »
CoppeliaSim Pro version 4.5.1 rev 4
Qt version 5.15.0 MSV2019
Build Apr 12 2023
If you set a large range over 100 (example minimum=0 and maximum=400), the parameter "value" doesn't work properly if it's >100
screenshot link:https://drive.google.com/file/d/1V8Pq97 ... sp=sharing
<group layout="grid">
	<label text="test1"/>
        <hslider tick-position="above" value="400" tick-interval="20" minimum="0" maximum="400" on-change="UIActuatorChange" id="2010"/><br/>
	<label text="test2"/>
        <hslider tick-position="above" value="200" tick-interval="20" minimum="0" maximum="400" on-change="UIActuatorChange" id="2011"/><br/>
	<label text="test3"/>
        <hslider tick-position="above" value="100" tick-interval="20" minimum="0" maximum="400" on-change="UIActuatorChange" id="2012"/><br/>
	<label text="test4"/>
        <hslider tick-position="above" value="50" tick-interval="20" minimum="0" maximum="400" on-change="UIActuatorChange" id="2013"/>
</group>
javqui
Re: QT UI hslider initial value can't exceed 100
Post by javqui »
just if somebody need it:
workaround
...activeUI=simUI.create(xml)
simUI.setSliderValue(activeUI,2010,400,true)
simUI.setSliderValue(activeUI,2011,200,true)
the other 2 values below or at 100 works directly in the initial "value" property declaration
are you on macOS? We are able to reproduce that on macOS, but not on Windows. It appears to be a Qt related bug...
edit: sorry I was wrong, indeed the bug also affects Windows and probably Ubuntu too, but should be fixed in today's rev8 release
