I am trying to set up a deep reinforcement learning framework by interfacing CoppeliaSim with StableBaselines3 package. This interfacing has worked fine and the training takes place for a while (~10 mins) after which the system crashes with the following error (attached as an image). https://drive.google.com/file/d/1QPhZCo ... sp=sharing
The training freezes on ~15% : https://drive.google.com/file/d/1YDBi1D ... sp=sharing
I believe this is some sort of memory/cache overload error. Can anyone please advise on how to approach this?
I have been using latest version of CoppeliaSim (CoppeliaSim_Edu_V4_6_0_rev8_Ubuntu22_04) on Ubuntu 22.
Thank you
Stack overflow error
Re: Stack overflow error
yes, we are aware of this bug, and a fix should come out by tomorrow (rev. 10). In the mean time, try to replace the content of addOns/simAddOnZMQ remote API server.lua with following:
sim = require 'sim'
removeLazyLoaders()
zmqRemoteApi = {}
function sim.setThreadAutomaticSwitch()
-- Shadow the original function
sim.stopSimulation = wrap(sim.stopSimulation, function(origFunc)
return function()
for k, v in pairs(allClients) do
v.steppingLevel = 0
v.holdCalls = 0
v.desiredStep = currentStep + 10
origFunc()
end)
sim.acquireLock = wrap(sim.acquireLock, function(origFunc)
return function()
if currentFunction == 'sim.acquireLock' then
currentClientInfo.holdCalls = currentClientInfo.holdCalls + 1
origFunc()
end)
sim.releaseLock = wrap(sim.releaseLock, function(origFunc)
return function()
if currentFunction == 'sim.releaseLock' then
if currentClientInfo.holdCalls > 0 then
currentClientInfo.holdCalls = currentClientInfo.holdCalls - 1
origFunc()
end)
function sim.restartServer()
leaveRequest = true
function sim.setThreadSwitchTiming(switchTiming)
-- 0=disabled, otherwise switchTiming
if switchTiming == 0 then switchTiming = 999999999 end
if sim.getSimulationState() == sim.simulation_stopped then
msgQueueTimeout_idle = switchTiming
msgQueueTimeout_running = switchTiming
sim.wait = wrap(sim.wait, function(origFunc)
return function(dt, simTime)
if not simTime then
local st = sim.getSystemTime()
while sim.getSystemTime() - st < dt do _yield() end
origFunc(dt, true)
end)
sim.setStepping = wrap(sim.setStepping, function(origFunc)
-- Shadow original function:
-- When stepping is true, CoppeliaSim ALWAYS blocks while Python runs some code
-- When stepping is false, CoppeliaSim run concurently to Python, i.e. Python is "free" (until a request from Python comes)
return function(enabled)
local retVal = 0
if currentFunction == 'sim.setStepping' then
retVal = currentClientInfo.steppingLevel
if enabled then
if currentClientInfo.steppingLevel == 0 then
currentClientInfo.desiredStep = currentStep
currentClientInfo.steppingLevel = currentClientInfo.steppingLevel + 1
if currentClientInfo.steppingLevel > 0 then
currentClientInfo.steppingLevel = currentClientInfo.steppingLevel - 1
retVal = origFunc(enabled)
return retVal
end)
nakedYield = sim.yield
function sim.step()
currentClientInfo.ignoreCallDepth = true
if sim.getSimulationState() ~= sim.simulation_stopped and sim.getSimulationState() ~= sim.simulation_paused then
currentClientInfo.desiredStep = currentStep + 1
local cs = currentStep
while cs == currentStep do
-- stays inside here until we are ready with next simulation step
zmqRemoteApi.send({func = '_*wait*_', args = {}}) -- Tell the client to wait and send '_*executed*_' back
nakedYield()
-- if we arrived here, we have received the '_*executed*_' reply from the same client
currentClientInfo.ignoreCallDepth = false
sim.switchThread = sim.step
sim.yield = sim.step
sim.readCustomDataBlock = wrap(sim.readCustomDataBlock, function(origFunc)
-- via the remote API, we should always return a string:
return function(obj, tag)
local retVal = origFunc(obj, tag)
if retVal == nil then retVal = '' end
return retVal
end)
function tobin(data)
local d = {data = data}
setmetatable(d, {
__tocbor = function(self)
return cbor.TYPE.BIN(self.data)
end,
return d
function totxt(data)
setmetatable(d, {
return cbor.TYPE.TEXT(self.data)
end,
return d
function toarray(data)
setmetatable(d, {
return cbor.TYPE.ARRAY(self.data)
end,
return d
function tomap(data)
setmetatable(d, {
return cbor.TYPE.MAP(self.data)
end,
return d
function zmqRemoteApi.verbose()
return sim.getNamedInt32Param('zmqRemoteApi.verbose') or 0
function zmqRemoteApi.require(name)
_G[name] = require(name)
zmqRemoteApi.parseFuncsReturnTypes(name)
if not sim.getBoolParam(sim.boolparam_execunsafeext) then
sim.executeScriptString = nil
sim.launchExecutable = nil
if simSubprocess then
simSubprocess.exec = nil
simSubprocess.execAsync = nil
-- more in sysCall_init and zmqRemoteApi.handleRequest
function zmqRemoteApi.parseFuncsReturnTypes(nameSpace)
local funcs = sim.getApiFunc(-1, '+' .. nameSpace .. '.')
for i = 1, #funcs, 1 do
local func = funcs[i]
local inf = sim.getApiInfo(-1, func)
local p = string.find(inf, '(', 1, true)
if p then
inf = string.sub(inf, 1, p - 1)
p = string.find(inf, '=')
if p then
local t = {}
local i = 1
for token in (inf .. ","):gmatch("([^,]*),") do
p = string.find(token, ' ')
if p then
token = string.sub(token, 1, p - 1)
if token == 'string' then
t[i] = 1
elseif token == 'buffer' then
t[i] = 2
elseif token == 'map' then
t[i] = 3
t[i] = 0
t[i] = 0
i = i + 1
returnTypes[func] = t
returnTypes[func] = {}
function zmqRemoteApi.info(obj)
if type(obj) == 'string' then obj = zmqRemoteApi.getField(obj) end
if type(obj) ~= 'table' then return obj end
local ret = {}
for k, v in pairs(obj) do
if type(v) == 'table' then
ret[k] = zmqRemoteApi.info(v)
elseif type(v) == 'function' then
ret[k] = {func = {}}
elseif type(v) ~= 'function' then
ret[k] = {const = v}
return ret
function zmqRemoteApi.getField(f)
local v = _G
for w in string.gmatch(f, '[%w_]+') do
v = v[w]
if not v then return nil end
return v
function zmqRemoteApi.handleRequest(req)
currentClientInfo.callDepth = currentClientInfo.callDepth + 1
-- Handle buffered async calls first:
local tmp = asyncFuncCalls
asyncFuncCalls = {}
for i = 1, #tmp, 1 do zmqRemoteApi.callRemoteFunction(tmp[i].func, tmp[i].args) end
if zmqRemoteApi.verbose() > 1 then print('Received request:', req) end
local resp = {}
if req['func'] ~= nil and req['func'] ~= '' then
local reqFunc = req['func']
local func = zmqRemoteApi.getField(reqFunc)
local args = req['args'] or {}
if not func then
resp['err'] = 'No such function: ' .. reqFunc
currentFunction = reqFunc
if func == sim.callScriptFunction then
if #args > 0 and (args[1] == '_evalExec' or args[1] == '_evalExecRet') and
args[1] = "FORBIDDEN"
-- more in sysCall_init and zmqRemoteApi.require
-- Handle function arguments and possible nil values:
for i = 1, #args, 1 do
if type(args[i]) == 'string' then
if args[i]:sub(-5) == "@func" then
local nm = args[i]:sub(1, -6)
args[i] = function(...) return zmqRemoteApi.callRemoteFunction(nm, {...}, true) end
elseif args[i] == '_*NIL*_' then
args[i] = nil
local function errHandler(err)
local trace = debug.traceback(err)
local p = string.find(trace, "\nstack traceback:")
if p then
trace = trace:sub(1, p - 1) -- strip traceback from xpcall
-- Make sure the string survives the passage to Python unmodified:
trace = string.gsub(trace, "\n", "_=NL=_")
trace = string.gsub(trace, "\t", "_=TB=_")
return trace
local status, retvals = xpcall(function()
local ret = {func(unpack(args, 1, req.argsL))}
-- Try to assign correct types to text and buffers:
local args = returnTypes[reqFunc]
if args then
local cnt = math.min(#ret, #args)
for i = 1, cnt, 1 do
if args[i] == 1 then
ret[i] = totxt(ret[i])
elseif args[i] == 2 then
ret[i] = tobin(ret[i])
elseif type(ret[i]) == 'table' then
if table.isarray(ret[i]) then
ret[i] = toarray(ret[i])
ret[i] = tomap(ret[i])
return ret
end, errHandler)
resp[status and 'ret' or 'err'] = retvals
currentFunction = nil
elseif req['eval'] ~= nil and req['eval'] ~= '' then
local status, retvals = pcall(
function()
-- cannot prefix 'return ' here, otherwise non-trivial code breaks
local ret = {loadstring(req['eval'])()}
return ret
currentClientInfo.callDepth = currentClientInfo.callDepth - 1
return resp
function zmqRemoteApi.poll()
local retVal = false
if receiveIsNext then
local rc, revents = simZMQ.poll({rpcSocket}, {simZMQ.POLLIN}, 0)
retVal = (rc > 0)
error('Trying to receive data from Python where a send is expected')
return retVal
function zmqRemoteApi.receive()
local retVal = nil
local rc, dat = simZMQ.recv(rpcSocket, 0)
receiveIsNext = false
rc, retVal = pcall(cbor.decode, dat)
if not rc then
if #dat < 2000 then
error(retVal .. "\n" .. sim.transformBuffer(dat, sim.buffer_uint8, 1, 0, sim.buffer_base64))
error('Error trying to decode received data:\n' .. retVal)
return retVal
function zmqRemoteApi.send(reply)
if not receiveIsNext then
local dat = reply
local status, reply = pcall(cbor.encode, reply)
if not status then
local s2, rep2 = pcall(getAsString, dat)
if s2 then
error(reply .. "\n" .. rep2)
error('Error while trying to encode data to send:\n' .. reply)
currentClientInfo.idleSince = sim.getSystemTime()
simZMQ.send(rpcSocket, reply, 0)
receiveIsNext = true
error('Trying to send data to Python where a receive is expected')
function zmqRemoteApi.handleQueue()
local startTime = sim.getSystemTime()
-- First remove old clients:
local to = 10 * 60
if v.timeout then
to =v.timeout
if startTime - v.idleSince > to then
allClients[k] = nil
break
local clients = {}
local clientCnt = 0
local msgCnt = 0
while not leaveRequest do
local dataPresent = zmqRemoteApi.poll()
if dataPresent then
msgCnt = msgCnt + 1
local req = zmqRemoteApi.receive()
if req.uuid then
-- req.ver currently 2. Is sent only for the first contact
if req.lang then
auxFunc('stts', 'zmqRemoteApiConnection-' .. req.lang)
if req.func == '_*end*_' then
zmqRemoteApi.send({})
allClients[req.uuid] = nil -- the client left
zmqRemoteApi.setClientInfoFromUUID(req.uuid, req.timeout)
currentClientInfo.lastReq = req
zmqRemoteApi.resumeCoroutine() -- simZMQ.send in there
if clients[req.uuid] == nil then
clientCnt = clientCnt + 1
clients[req.uuid] = true
auxFunc('stts', 'zmqRemoteApiConnection-???')
-- Previous version of ZMQ remote API
currentClientInfo = {} -- to avoid error in next:
zmqRemoteApi.send({
success = false,
error = "The client ZeroMQ remote API version does not match CoppeliaSim's version",
local maxWaitTime = -1
if msgCnt > 0 then
if sim.getSimulationState() & sim.simulation_advancing == 0 then
maxWaitTime = msgQueueTimeout_idle
maxWaitTime = msgQueueTimeout_running * clientCnt
if sim.getSystemTime() - startTime > maxWaitTime then break end
function zmqRemoteApi.setClientInfoFromUUID(uuid, optionalTimeoutInSecs)
currentClientInfo = allClients[uuid]
if currentClientInfo == nil then
local cor = coroutine.create(coroutineMain)
corout = cor,
idleSince = systTime,
lastReq = nil,
steppingLevel = 0,
desiredStep = currentStep,
callDepth = 0,
holdCalls = 0,
timeout = optionalTimeoutInSecs
allClients[uuid] = currentClientInfo
function zmqRemoteApi.resumeCoroutine()
if coroutine.status(currentClientInfo.corout) ~= 'dead' then
local ok, errorMsg = coroutine.resume(currentClientInfo.corout)
if errorMsg then
error(debug.traceback(currentClientInfo.corout, errorMsg), 2)
function sim.testCB(a, cb, b)
for i = 1, 99, 1 do cb(a, b) end
return cb(a, b)
function coroutineMain()
-- each client stays in here until timeout. Socket reads always happend in the 'handleQueue' (with an exception in callRemoteFunction)
while true do
-- Here we always have a request pending that we need to process and answer
local req = currentClientInfo.lastReq
local reply = zmqRemoteApi.handleRequest(req) -- We might yield in there, with blocking functions or callback functions
nakedYield() -- we only resume once a new request has arrived from the same client
function sysCall_info()
return {
autoStart = sim.getNamedBoolParam('zmqRemoteApi.autoStart') ~= false,
menu = 'Connectivity\nZMQ remote API server',
load = nil
loadfile = nil
dofile = nil
io.open = nil
io.popen = nil
os.execute = nil
os.remove = nil
-- more in zmqRemoteApi.require and zmqRemoteApi.handleRequest
returnTypes = {}
simZMQ = require 'simZMQ'
simZMQ.__raiseErrors(true) -- so we don't need to check retval with every call
zmqRemoteApi.parseFuncsReturnTypes('sim')
zmqRemoteApi.parseFuncsReturnTypes('simZMQ')
rpcPort = sim.getNamedInt32Param('zmqRemoteApi.rpcPort') or 23000
msgQueueTimeout_idle = 0.05
msgQueueTimeout_running = 0.002
if zmqRemoteApi.verbose() > 0 then
sim.addLog(
sim.verbosity_scriptinfos,
string.format('ZeroMQ Remote API server starting (rpcPort=%d)...', rpcPort)
cbor = require 'org.conman.cbor'
context = simZMQ.ctx_new()
rpcSocket = simZMQ.socket(context, simZMQ.REP)
simZMQ.bind(rpcSocket, string.format('tcp://*:%d', rpcPort))
sim.addLog(sim.verbosity_scriptinfos, 'ZeroMQ Remote API server started')
setAutoYield(false)
currentStep = 0
insideExtCall = 0
asyncFuncCalls = {}
currentClientInfo = nil
allClients = {} -- uuid is the key, e.g.:
-- allClients.uuidXXX.corout
-- allClients.uuidXXX.idleSince
-- allClients.uuidXXX.lastReq
-- allClients.uuidXXX.steppingLevel
-- allClients.uuidXXX.desiredStep
-- allClients.uuidXXX.holdCalls
-- allClients.uuidXXX.callDepth
-- allClients.uuidXXX.ignoreCallDepth
-- allClients.uuidXXX.timeout
initSuccessful = true
function zmqRemoteApi.callRemoteFunction(functionName, _args, cb)
-- This is called when a CoppeliaSim function (e.g. sim.moveToConfig) calls a callback
zmqRemoteApi.send({func = functionName, args = _args})
local retVal
if insideExtCall > 0 and cb then
-- Yielding has no effect, since we might be in a callback from a c routine (after a lua - c-boundary crossing, yieling doesn't work)
while true do
if zmqRemoteApi.poll() then
if currentClientInfo == allClients[req.uuid] then
if req.func ~= '_*executed*_' then
retVal = req.args
break
zmqRemoteApi.send({func = '_*repeat*_', args = {}}) -- Tell the client to repeat the request, since we are busy now
while true do
nakedYield()
-- if we arrived here, we have received a reply from the client, either the '_*executed*_' reply or a request to call a function
retVal = req.args
break
return unpack(retVal)
function sysCall_cleanup()
if initSuccessful then
sim.setScriptInt32Param(sim.handle_self, sim.scriptintparam_autorestartonerror, 1)
if simZMQ then
simZMQ.close(rpcSocket)
simZMQ.ctx_term(context)
sim.addLog(sim.verbosity_scriptinfos, 'ZeroMQ Remote API server stopped')
function sysCall_addOnScriptSuspend()
return {cmd = 'cleanup'}
function sysCall_addOnScriptSuspended()
function sysCall_nonSimulation()
local retVal
local holdCalls = true
while holdCalls do
holdCalls = false
if not leaveRequest then
if v.holdCalls > 0 then holdCalls = true end
if v.callDepth > 0 and not v.ignoreCallDepth then waitForStep = true end
if leaveRequest then retVal = {cmd = 'restart'} end
return retVal
function sysCall_actuation()
local retVal
local waitForStep = true
while waitForStep do
waitForStep = false
if v.steppingLevel > 0 then
if v.desiredStep <= currentStep then waitForStep = true end
waitForStep = true
if v.holdCalls > 0 then waitForStep = true end
currentStep = currentStep + 1
return retVal
function sysCall_ext(funcName, ...)
local retVal
insideExtCall = insideExtCall + 1
local fun = _G
if string.find(funcName, "%.") then
for w in funcName:gmatch("[^%.]+") do -- handle cases like sim.func or similar too
if fun[w] then fun = fun[w] end
fun = fun[funcName]
if type(fun) == 'function' then
retVal = fun(...)
asyncFuncCalls[#asyncFuncCalls + 1] = {func = funcName, args = {...}}
insideExtCall = insideExtCall - 1
return retVal
function sysCall_afterSimulation()
currentStep = 0
--[[ disable following to keep a similar behaviour as Lua scripts, that keep their stepping behaviour past a simulation run
for k,v in pairs(allClients) do
v.steppingLevel = 0
