Running several scenes in parallel, is possible?
Guilherme.aut
Post by Guilherme.aut »
Hello!
I would like to know if there is the possibility of running several scenes in parallel?
I'm currently using:
- version 4.6.0 of Coppelia;
- python 3.11.5;
- ZeroMQ remote API;
Re: Running several scenes in parallel, is possible?
yes, you can run several simulations in parallel, you will however need to run several instances of CoppeliaSim. Each one should then use a different ZeroMQ remote APi server port. You can do this by starting CoppeliaSim as follows:
coppeliaSim -GzmqRemoteApi.rpcPort=portNb
you might however need to append 2 dummy chars as in following example, depending on your CoppeliaSim version/revision (see also this reply):
coppeliaSim -GxxzmqRemoteApi.rpcPort=portNb
Guilherme.aut
Well, I need more information to understand this.
- I updated my Coppelia to: V4.6.0 rev14.
- I use ZeroMQ remote API.
- I currently connect to Coppelia like this:
client = RemoteAPIClient()
sim = client.require('sim')
sim.setStepping(True)
sim.startSimulation()
sim.setBoolParam(sim.boolparam_display_enabled,False)
- To connect multiple scenes in parallel, what do I need to do? What do I need to change? Is there a step-by-step guide explaining how to do this?
With CoppeliaSim V4.6.0 rev14 and later, you need to start each instance's ZeroMQ remote API server on a different port:
On the ZeroMQ remote API client side, you need to explicitly connect to one of the ports from above:
client = RemoteAPIClient('localhost', portNb)
Guilherme.aut
Right. What values ​​for "portNb" can I use? Could you give me some examples? Is there a list of recommended values?
e.g. 23001, 23002, 23003, etc.
Guilherme.aut
Ok!
Just one more question. Should this command line "coppeliaSim -GzmqRemoteApi.rpcPort=portNb" be used in the Linux terminal to open Coppelia? Why don't I open Copppelia through the terminal. I looked for this on the internet and I didn't find anything.
Guilherme.aut
Ok, I think everything is fine here! The correct command line is ".\coppeliaSim.sh -GzmqRemoteApi.rpcPort=portNb".
Thank so much!!!!
Thank you for helping me! I am very grateful!
zhengkz
Post by zhengkz »
I wonder if I use coppeliasim.bridge.load() to open several instances in different threads. Do I still need to set the port for different instances? If it is needed, how to set that? Thanks!
Best,
Kz
No, coppeliasim.bridge doesn't use ZMQ remote API.
