I wonder how to import/export URDF through API. I tried to use simURDF.import, but it shows attempt to index a nil value (global 'simURDF')
Best,
Kz
URDF API
Re: URDF API
To load a plugin:
simURDF = require('simURDF')
Re: URDF API
It seems only to support Lua API. If I want to use it with Python, what will be the best way to implement that? Thanks!
Best,
Kz
Best,
Kz
Re: URDF API
Works also in Python:
[sandboxScript:info] Simulator launched, welcome!
[simCmd:warning] Sandbox language: Python
> sys.version
'3.11.6 (main, Nov 2 2023, 04:39:43) [Clang 14.0.3 (clang-1403.0.22.14.1)]'
> [method for method in dir(simURDF) if not method.startswith('__')]
['export', 'import', 'importFile', 'pluginHandle', 'sendTF']
