Simulation freezes in Stepping Mode
major_david
Post by major_david »
I'm working on a project using Coppelia as a simulation environment for reinforcement learning. The simulation is configured on Stepping Mode. Everything looks great, and most of the time I get the desired results from Coppelia. However, during the training, sometimes the simulation freezes without any errors. I used some tools to find which line the Python stopped working. Apparently, the simStep() function is called but the ZMQremote API fails to execute it, and the program freezes. The traceback is as follows:
    self.sim.step()
  File "/home/major/anaconda3/envs/Main3/lib/python3.11/site-packages/coppeliasim_zmqremoteapi_client/__init__.py", line 161, in <lambda>
    setattr(ret, k, lambda *a, func=f'{name}.{k}': self.call(func, a))
  File "/home/major/anaconda3/envs/Main3/lib/python3.11/site-packages/coppeliasim_zmqremoteapi_client/__init__.py", line 147, in call
    reply = self._recv()
  File "/home/major/anaconda3/envs/Main3/lib/python3.11/site-packages/coppeliasim_zmqremoteapi_client/__init__.py", line 106, in _recv
    rawResp = self.socket.recv()
  File "zmq/backend/cython/socket.pyx", line 805, in zmq.backend.cython.socket.Socket.recv
  File "zmq/backend/cython/socket.pyx", line 841, in zmq.backend.cython.socket.Socket.recv
  File "zmq/backend/cython/socket.pyx", line 194, in zmq.backend.cython.socket._recv_copy
  File "zmq/backend/cython/checkrc.pxd", line 13, in zmq.backend.cython.checkrc._check_rc
I'm using the latest version of Coppelia(rev16) alongside Python 3.11.
Re: Simulation freezes in Stepping Mode
I think there are missing lines in the error output.
Best would be if you could provide a minimalistic, self-contained script that triggers the error, but I guess that would be difficult.
Can you try to use the local source instead, i.e.:
# instead of:
from coppeliasim_zmqremoteapi_client import RemoteAPIClient
# do:
from zmqRemoteApi import RemoteAPIClient
Then you could modify the code via some prints in programming/zmqRemoteApi/clients/python/src/coppeliasim_zmqremoteapi_client/__init__.py
But it appears that ZMQ fails to receive some data, but the reason is not indicated/missing in your error output
Aidewen
Post by Aidewen »
Hi, I seem to be facing the same issue.
I'm using ZMQRemoteAPI and I'm running python code in a multiprocessing thread (Manager). The python code opens the coppelia executable in headless mode as follows.
 args = {
            'stdin' :         subprocess.DEVNULL,
            'stderr':         subprocess.PIPE,
            'stdout':         subprocess.PIPE,
            'startupinfo':    startupinfo,
            'env'   :         env,
            'creationflags':  subprocess.CREATE_NEW_PROCESS_GROUP + subprocess.CREATE_NEW_CONSOLE
subprocess.Popen([coppeliapath, '-GzmqRemoteApi.rpcPort=' + str(port), '-h'], shell=True, **args)
SetStepping is set to true, but the code seems to freeze after the third step in "self.cntsocket.recv(0 if wait else zmq.NOBLOCK)" in getStepCount from RemoteAPIClient. I recently discovered the emulated headless mode, so this issue is not present if I don't use it. Also, headless mode is not an issue if I don't use threading python packages. Any suggestions?
Context:
  • OS: Windows 10
  • CoppeliaSim: V.4.5.1
  • Python: 3.8.18
  • Packages: `subprocess`, `psutil`, `multiprocessing.Manager`
  • RemoteAPI: ZMQ
make sure to use the latest CoppeliaSim, since CoppeliaSim V4.6 features a much improved Python support.
Aidewen
Post by Aidewen »
Unfortunately, I am not able to upgrade to a higher edition as the current code I am working with requires a previous version.
Fortunately, I was able to locate the source of my problems. I was loading the RG2 model with a lua script code that seem to be incompatible with the simulation during runtime in headless mode.
function sysCall_sensing()
    local s=sim.getObjectSel()
    local show=(s and #s==1 and s[1]==modelHandle)
    if show then
        if not ui then
            local xml =[[<ui title="xxxx" closeable="false" placement="relative" layout="form">
                    <button id="1" text="open" checkable="true" checked="true" auto-exclusive="true" on-click="openClicked"/>
                    <button id="2" text="close" checkable="true" auto-exclusive="true" on-click="closeClicked"/>
            </ui>]]
            ui=simUI.create(xml)
            if uiPos then
                simUI.setPosition(ui,uiPos[1],uiPos[2])
                uiPos={}
                uiPos[1],uiPos[2]=simUI.getPosition(ui)
            simUI.setTitle(ui,sim.getObjectAlias(modelHandle,1))
            simUI.setButtonPressed(ui,1,not closing)
            simUI.setButtonPressed(ui,2,closing)
        if ui then
            simUI.destroy(ui)
            ui=nil
After that, everything runs smoothly.
Aidewen wrote: 12 Mar 2024, 16:44 Unfortunately, I am not able to upgrade to a higher edition as the current code I am working with requires a previous version.
Can you tell us what exactly is not compatible, so that we can improve on this?
Aidewen
Post by Aidewen »
So if the python code (using ZeroMQ) is running coppelia in headless mode and there is a lua script attached to a model that runs code during actuation as follows,
or
 if not ui then
    	</ui>]]
It will freeze the simulation stepping of the python code.
You can try the following python code:
try:
    # If Coppelias Sim Version 4.5.1
    from src.coppeliasim_zmqremoteapi_client import RemoteAPIClient
except:
    # If Coppelias Sim Version 4.3 to 4.4
import sys
sys.path.insert(0,'..')
from mmsl_lib.utils import global_configs
import os
import time
import subprocess, psutil
def _get_full_path(filename:str) -> str:
    "Retrieves the full path of a file."
    filename = os.path.abspath(filename)
    assert os.path.exists(filename), 'File path does not exist!'
    return filename
def _popen(cmd: list) -> subprocess.Popen:
    "Opens a new process using subprocess.Popen."
    env = os.environ
    env.setdefault("QT_DEBUG_PLUGINS","1")
    startupinfo = subprocess.STARTUPINFO()
    startupinfo.dwFlags |= subprocess.STARTF_USESHOWWINDOW
    args = {
        'env'   :         env,
    process = subprocess.Popen(cmd, shell=True, **args)
    return process
def run(headless: bool = False):
    gconfigs = global_configs('../configs/configs.ini')
    coppeliapath = 'path/to/coppelia/exe'
    host='localhost'
    port = 23002
    model_path = 'path/to/model/ttm'
    'Opening CoppeliaSim'
    print('Opening Coppelia')
    coppeliapath = _get_full_path(coppeliapath)
    options = [coppeliapath, '-GzmqRemoteApi.rpcPort=' + str(port)]
    if headless: options += ['-h']
    app = _popen(options)
    time.sleep(5) #Waiting for CoppeliaSim to Open
    parent = psutil.Process(app.pid) # getting id from opened CoppeliaSim exe
    app = parent.children(recursive=True)
    client = RemoteAPIClient(host, port)
    client.setStepping(True)
    sim = client.getObject('sim')
    print('Loading Model')
    sim.loadModel(_get_full_path(model_path))
    print('Starting Simulation Model')
    sim.startSimulation()
    print('Waiting 10 Secs (Simulation)')
    client._wait(10, True)
    print('Ending Simulation Model')
    sim.stopSimulation()
    print('Closing Coppelia')
    if app != None:
        time.sleep(2.0) #Sleeping before Terminating CoppeliaSim Executable
        for ps in app:
            subprocess.check_output("Taskkill /PID %d /F" % ps.pid)
        app = None
if __name__ == '__main__':
    run(headless=True)
    print('Completed')
And create the following nonthreaded lua script in a model:
    -- do some initialization here
function sysCall_actuation()
    -- put your actuation code here
    --#Issue num 1
    --local s=sim.getObjectSel()
    --#Issue num 2
    if not ui then
        </ui>]]
function sysCall_cleanup()
    -- do some clean-up here
This will replicate the issue I'm facing. We have to be careful what functions are used in headless mode!
it is very difficult to find out what exactly is going on. Normally one should not start CoppeliaSim via a Python script, since this could confuse Qt which requires CoppeliaSim to be started in the main thread.
There is however the Python application client in V4.6, that allows to start and run CoppeliaSim via Python, e.g. python coppeliaSim.py
In there however too, you can easily block CoppeliaSim if not careful, since Python code will run the Python script and the main simulation loop successively.
