How to pass signal in function sysCall_thread()
YZHOU035
Post by YZHOU035 »
Hi Development team, I met a problem in reading signal in my Child script "/UR10". Specifically, I want to only preceed the robot motion when it get the signal indicating that the object has been put in the correct place, and the Child script of the conveyor is:
--lua
sim=require'sim'
    self=sim.getObject('.')
    sensor=sim.getObject('./_sensor')
function sysCall_actuation()
    --if (sim.getInt32Signal('ActivateBelt') == 1) then
        --beltVelocity=0.08
    --else
        --beltVelocity=0.0
    --end
    beltVelocity=0.08
    if sim.readProximitySensor(sensor)>0 then
        beltVelocity=0
        sim.setInt32Signal('pickup_Ready', 1)
        sim.clearInt32Signal('pickup_Ready')
    sim.writeCustomTableData(self,'__ctrl__',{vel=beltVelocity})
I can correctly read the signal changes using the signal monitor tool. However in my UR10 script as following (part of):
function waitForSensor()
    sim.waitForSignal('pickup_Ready')
    object_picked = 0
    while object_picked < 3 do
        waitForSensor()
        -- STEP I
        goToPickPos()
        sim.wait(0.5)
        -- STEP II
        activateVacuum()
        sim.wait(0.5)
        -- STEP III
        goToDropPos()
        sim.wait(0.5)
        -- STEP IV
        releaseVacuum()
        sim.wait(0.5)
        object_picked = object_picked + 1
    goToInitPos()
    sim.stopSimulation()
The waitForSensor function does not work and the robot would not move. Can anyone please help me how to fix this problem? Thanks a lot.
Re: How to pass signal in function sysCall_thread()
this works fine:
-- lua
    sim = require('sim')
    i = 0
    i = i + 1
    if i == 1000 then
        print("Signal set")
        sim.setInt32Signal("pickup_Ready", 1)
-- lua
    print("Waiting")
    waitForSensor()
    print("Signal received")
